Old 11-27-2015, 10:46 AM   #1
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Tires
Hello
already to be here an old theme, I was searching the forum but found nothing about changing tires for other
I'm with the issue of changing my tires 16.5 16 inch other.
watching my old tires have a capacity to withstand almost 2000 pounds, when I add 6 tires'm almost at the limit of capacity as the Argosy weighs 6.2 tons
I have this question now, some of you may shift by 16 inches? if any change could happen to me the extent of the tires? and how much weight each support
Thank you
Herman
german6563 is offline   Reply With Quote
Old 11-27-2015, 10:49 AM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Look at the load range indicator on the original tires. As long as you stay with that load range or higher you should be fine.
92landyacht is offline   Reply With Quote
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
tires radials or bias ply tires larry b Tires 22 06-27-2010 05:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
