Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 10-24-2007, 02:01 PM   #1
Geophilist
Profile:  Norfolk , Virginia
Timing troubles
I have an '82 Excella MoHo with a stock 454 with low milage (36k). I am having trouble geting her timing set.
I set up on #5 cylinder, vacuum disconnected and pluged, and am using the timing marks on the oil sump. When I set the timing at factory recommended 4 degrees bthc, the engine runs really rough. If I go to about 16 degrees btdc it smothes out.
Does anyone have any ideas as to what is going on?
Steve
Geophilist is offline   Reply With Quote
Old 10-24-2007, 04:31 PM   #2
safari57
safari57's Avatar
Profile:  1951 21' Flying Cloud
West Coast , BC
Steve
I have never used any other cylinder but #1 to set the timing. I've tuned a lot of big block Chevy's and this is the first I've heard of using another cylinder.
Is there a trick I never knew about?
Did you have the distributor out?
Barry
Traveling Swell
Barry & Donna
Life is short - so's the door on an Flying Cloud (ouch)
AIR #7364 WBCCI #8110 member 4CU
safari57 is online now   Reply With Quote
Old 10-24-2007, 08:10 PM   #3
drag'nwagon
drag'nwagon's Avatar
Profile:  1974 31' Sovereign
1956 26' Cruiser Overlander
Lambertville , Michigan
Try and time it on #1, if you cant get it there than you have another issue.
Dave
Operation "Save Rudy" Strike Team (charter member)
You mess with the Strike Team,... you mess with the whole trailer park!!
drag'nwagon is offline   Reply With Quote
Old 10-25-2007, 10:13 AM   #4
Geophilist
Barry and Dave,
You can't really see the markings on the motorhome in the usual place, and that is why they put markings on the underside of the coach. The indicators are 180 degrees from the topside ones, so you have to set up on #5, which, I believe, is 180 degrees from #1. Or so I have read here.
I have not taken out the distributor, but perhaps a PO did so. I have had this coach a long while, and it always wants high test or it pings. I am envious of those of you who are able to use regular, so I am trying to get to that point if I can.
Thanks.
Steve
Old 10-30-2007, 01:56 PM   #5
Robfike
Robfike's Avatar
Profile:  Speedway , Indiana
I have not checked/set the timing yet on our '86 345. It runs great on 87 octane regular. Try checking with Steven Webster, he has used the #5 procedure.
Rob
Robfike is offline   Reply With Quote
Awning Troubles Alaska1966 Awnings 1 08-01-2007 12:51 PM
Help, 12 volt troubles cookeville34 Electrical - Systems, Generators, Batteries & Solar 24 12-24-2006 08:20 AM
454 engine troubles tx-lawman Mechanics Corner - Engines, Transmission & More... 45 10-02-2006 10:08 PM
Water troubles... Sneakinup Fresh Water Systems 5 01-10-2004 10:54 PM
