Old 04-21-2009, 11:44 PM   #1
pwhittle's Avatar
1982 31' Airstream310
Alpharetta , Georgia
Tilt Switch source?
I have various tilt switches on my MH. In the extra door lock, the steps, and the levelers. I assume they are mercury tilt switches about 3/8"to 1/2" diameter and 1 1/2" long with two wires connected.
Some of them have broken the wires off, and while I have had some success soldering them back on, I would prefer to find replacements.
I found something close and I need to measure to see if they are exact replacements at McMaster-Carr McMaster-Carr
Has anyone found a direct replacement?
Paul
1982 FFC with Motorhome Interior
http://shineee.whittlegroup.com
pwhittle is offline   Reply With Quote
Old 04-22-2009, 07:27 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
15 degrees seams like a large Differential Angle for your useage in a motor home. Other than that size would not effect operation.
2004 Excursion 4x4
Old 04-22-2009, 07:38 AM   #3
pwhittle's Avatar
15 degrees should be fine ir they fit. They are differentiating between horisontal and vertical.
Paul
Hehr vs. Full tilt windows. Soyboy Windows & Screens 28 03-17-2012 07:55 AM
Tilt Mechanism - Lookout Blinds xengineer Upholstery, Blinds, Walls & Interior Finishes 0 09-01-2008 05:09 PM
Switch? excella1976 General Interior Topics 2 01-17-2008 04:10 PM
What is this switch? alb 2005 and newer - Bambi all models 13 12-02-2007 07:25 PM
Parts source for four position light switch overlander76 Electrical - Systems, Generators, Batteries & Solar 6 11-16-2003 08:24 PM
