Old 08-07-2015, 07:06 PM   #43
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Thanks. I was too lazy to go back and find your post.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-07-2015, 07:10 PM   #44
2005 22' Interstate
san clemente , California
Maggie
You may want to think about alloy wheels like you saw on our Interstate. They are stronger than the stock steel wheels, no caps and I believe the lug bolts are stronger than original equipment, they also have a different flare angle I believe makes them more secure first time around. I paid about 550.00 for 5 wheels to especially fit the Sprinter, including the new lug bolts and metal valve stems. All problems we encountered before were solved. Call us if you want the name of the wheels. Sorry you're having this problem.
Ed
unifreck is offline   Reply With Quote
Old 08-07-2015, 07:42 PM   #45
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
We have "electric" impact wrench... With one of these:
Blue Point BTQS12T Torque Stick Socket 140 Foot Pounds 24mm 8 1 2 Inches | eBay
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 08-07-2015, 08:08 PM   #46
Lily&Me's Avatar
Normal , Illinois
Thanks for all the suggestions and info, everybody.
163,000+ miles, and we have not had this problem before. We drove together, and if there had been noise issues Doug would have spoken of it and I therefore would have known. I do remember us picking a screw or something up in a tire, and going in someplace to have it fixed.
I am certain Doug did not carry a lug wrench when we traveled....none in the tool bag, nor stashed in the rear...so there was something different this time. This was the third tire rotation since he died, I believe.
I will talk with the tire guys next week, when I hopefully will have the Interstate back.
I already spoke with them about buying a wrench, and they are glad to show me what to do.
Maggie
Old 08-07-2015, 08:09 PM   #47
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Maggie, I am beyond familiar with what you just went through. Glad you and Lily are OK. I have learned a LOT about ALUMINUM trailer wheels and the proper torque setting. There are a LOT of confounding factors with both wheels, studs, and lug nuts. This included a 1:1 with Chris Burch who runs the service part of Airstream on what is (and is not) the proper torque for a 16" aluminum trailer wheel. Fact is, there are a LOT of variables involved when wheels are new, and if you take them off for wheel rotation, or replacement. Barry
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-07-2015, 08:12 PM   #48
Lily&Me's Avatar
Normal , Illinois
Thanks, Barry.
I will get it figured out, and what to do.....even if that is finding a Firestone dealer periodically to have them checked.....which is probably not a bad idea.
Somehow, I don't see myself developing intimate knowledge of lug nut torqueing requirements, and then performing too much of that myself.
Something basic I can do, I will never be nor aspire to be a mechanic.
Maggie
Old 08-07-2015, 08:16 PM   #49
BAB
BAB's Avatar
2015 30' Classic
The good news is that the odds are now in your favor that this will NEVER happen again! For sure, you'll be on the alert to double check that whoever does your tire work in the future gets it right. You now have a story to tell them!
_________________
ProPride 3P
AIR# 58452
Old 08-07-2015, 08:20 PM   #50
Maggie - sorry for the hijack of your thread
Barry,
I went through the drum/stud/wheel torque quandary when I changed my wheels. I got widely differing numbers depending on where I looked. I saw one writeup that made sense to me that said the torque should be as determined by the stud. My 2001 manual has a number for steel wheels and a different number for aluminum wheels. Airstream has a third number or maybe even third and fourth for the Sendels. What did you come up with talking to Chris?
Al
S/OS #004
Old 08-07-2015, 08:33 PM   #51
BAB
BAB's Avatar
2015 30' Classic
Al, I have the Airstream Engineering Spec Sheet for TRAILER wheels in front of me. (Chris gave this to me in his office.) 15" or 16" steel wheels with either 6 or 5.5" bolt circles should be set between 90-120 ft lbs of torque. For ALUMINUM wheels 15" or 16" the setting is 110-120 ft lbs. The trick with aluminum wheels is the necessity for checking torque after they are first installed (this would include remounting). I order for the lug nut to seat properly in the (somewhat) softer aluminum, you need to check the torque after around 40 miles, then at around 100, again at 200. I found that every time I stopped to check the torque on the new wheel(s), I would get 1 or 2 clicks more. After 200 miles, they were well seated. HOWEVER, out of an abundance of caution, I carry the humongously long torque wrench with me and check all the lug nuts prior to starting a trip and along the way. Barry
_________________
ProPride 3P
AIR# 58452
Old 08-08-2015, 03:38 PM   #52
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by Protagonist View Post
133 lb-ft for lug nuts.
Maggie has an older 4 wheel Interstate with lug bolts. The 133 lb-ft is the number for the newer Interstates on Sprinter 3500 chassis with dual rear wheels and lug nuts. I don' think it applies to Maggie's Interstate.
Old 08-08-2015, 05:20 PM   #53
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
In that case it is 177 lb-ft for lug bolts and steel wheels, 133 lb-ft for alloy wheels and lug bolts. I stand corrected.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 08-08-2015, 06:27 PM   #54
Thanks Barry. I have observed the same need for re-torquing up to about 200 mi. After that, they stabilized.
Again, apologies to all for hijacking the thread.
Al
S/OS #004
Old 08-10-2015, 04:07 PM   #55
Lily&Me's Avatar
Normal , Illinois
I have the Interstate back....new wheel/tire, axle and everything else is okay. Just under $1,000.
The bad news is...they really can't tell me what happened, minus the wheel/tire which fell off and is in a cornfield somewhere west of Magnolia, Il.
The wheel would tell them a lot, they said....loose lug nuts would quickly damage their aluminum surrounds, leaving a telltale trail.
Likely a freak accident, was the conclusion, not something that could have been prevented.
They do not recommend me buying a torque wrench, and trying to maintain these myself to any extent whatsoever.
Better to come in there, or into another tire shop, to have the lug nuts tightened properly....is what they said.
If I hear those kind of noises again, and am in a remote area, better to call AAA than continue driving....is what they said.
It is disconcerting to think there isn't something I can do to prevent this from happening again. I do know I won't ask a teenager to check and tighten the lug nuts again. Who knew it was so complicated.
I am not going to let myself be fearful, but do know we were darned lucky.
Maggie
Old 08-10-2015, 04:27 PM   #56
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Maggie
Methinks it was less luck and more a big Guardian Angel..... But, that is just my way of seeing things... I have found many feathers from similar encounters... Also, I bet the tire assembly is now in a trophy room somewhere..
Channing
WBCCI# 30676
Checking tires-thumping method Bluto Tires 17 07-13-2014 06:08 AM
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 11:18 AM
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 12:49 PM
What the heck is this thing under the hood? bkahler Argosy Motorhomes 37 12-24-2012 09:19 PM
Under hood AC compressor dead Astrodokk Mechanics Corner - Engines, Transmission & More... 3 08-24-2009 10:53 PM
