Originally Posted by WayneG
Does this plenum replace the shroud (shown below) that goes between the throttle body and air cleaner?
I guess you must eliminate or change the vacuum hoses and PCV vent?
Just saw your question..the plenum sits on top of the shroud ring. You will also need to modify (shorten) the "dog leg" holding screw so as to seat it deeper in the throttle body. Still, haven't checked your diagram against my rig..will get back to you but suspect I've inadvertently eliminated the vacuum hookup
