Old 06-01-2015, 05:39 PM   #1
1995 36' Classic 36
Ludington , Michigan
The Killer Dowel Pin
When I bought the 95 I did a little research on the care and feeding of the Cummins 5.9. The killer dowel pin seemed to be the hot topic. All of the 12 valve and some of the early 24 valve engines have a potential catastrophic event lurking for the perfect opportunity to make your day suck.
Cummins used dowel pins to align the timing gear case with the block. Two are captive this little bastard can work its way out.
Name:	ImageUploadedByAirstream Forums1433201201.529756.jpg
You can see it between that bolt and the housing wall. Mine had migrated about 3/16" out. Another 1/4" and it would been free to go through the gears. Would it have continued to move? Who knows. It did tap back in with a small hammer and drift.
Name:	ImageUploadedByAirstream Forums1433201500.961266.jpg
The fix is cheap and simple but a PITA to install on the 360.
Name:	ImageUploadedByAirstream Forums1433201704.055479.jpg
Name:	ImageUploadedByAirstream Forums1433201738.473556.jpg
There are many YouTube videos on the procedure. I'll share the procedure of getting to it on the Classic 360 diesel pusher.
Kota is offline   Reply With Quote
Old 06-01-2015, 06:07 PM   #2
1995 36' Classic 36
After dealing with the overheating issues on the 94, I decided to pull the radiator/charge air cooler on the 95. It was running fairly cool unless you really pushed it in hot conditions. I pressure wash the radiator regularly so I was a little surprised with what I found.
Name:	ImageUploadedByAirstream Forums1433203098.151079.jpg
Name:	ImageUploadedByAirstream Forums1433203124.770504.jpg
Name:	ImageUploadedByAirstream Forums1433203148.987391.jpg
Name:	ImageUploadedByAirstream Forums1433203175.074346.jpg
Name:	ImageUploadedByAirstream Forums1433203205.091304.jpg
I'm estimating about a 25% blockage. There is also an unused "oil" cooler sandwiched between the radiator and the CAC. It's only purpose is to trap dirt and impede airflow.
I'll add more pictures tomorrow as I reinstall the radiator.
I did get the timing cover back on tonight to keep the dirt out.
Name:	ImageUploadedByAirstream Forums1433203585.994056.jpg
Name:	ImageUploadedByAirstream Forums1433203616.113863.jpg
Old 06-01-2015, 06:21 PM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Been there done that but it was after the pin walked out, tore up the gear case. Bought the truck after pin failure. Lots of labor, towels and lots of hand cleaner. I had to pull the camshaft to replace the gear case. I didn't own the truck when it happened. Well documented on several Dodge Cummins forums. Still running strong 7 years later.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 06-01-2015, 07:35 PM   #4
1974 Argosy 20
Kooskia , Idaho
Years ago on my 310 with the 454 I had a constant overheating situation. When I finally took all the front end apart to get to the radiator, I found the AC condenser, and the transmission cooler blocking the front of the radiator. They were not the problem, but over the years cottonwood silk, straw and oil from the road had plugged the lower half of the actual engine radiator with a matt so thick that no air could get through it at all. At least half of the surface was plugged up. This could not be seen from the front at all until the other things were removed.
After cleaning the grunk off, and re assembling it, the rig ran cool as a cucumber and would climb any grade in the West on a 100 + day with no issues.
So, you do need to do what you did, see the actual radiator surface. You can get quite a surprise when you do.
Old 06-02-2015, 02:56 PM   #5
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
If it was mine I would drill and tap and use red Loctite.
NavyCorpsman is offline   Reply With Quote
Old 06-02-2015, 03:15 PM   #6
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
When doing research for my motor rebuild, this was always the first thing that came up in articles and threads. Looks like anyone with this vintage of pusher should clean out their radiator and CAC, and install the KDP repair kit...two major potential problems fixed, money well spent.
SebasSF is offline   Reply With Quote
Old 06-02-2015, 04:23 PM   #7
1995 36' Classic 36
Name:	ImageUploadedByAirstream Forums1433283790.890558.jpg
Old 06-02-2015, 05:55 PM   #8
GCinSC2's Avatar
The KDP has been well documented on multiple forums. The tabs have been aftermarket supplied, made in garages and this one is shown on a Cummins package. Tabbing works and the pin keeps things lined up in the gearcase. Newer cases are step bored and the pin cannot come out.
S/OS #001
Old 06-03-2015, 12:35 PM   #9
1995 36' Classic 36
Found some leaks in my CAC. It's in a shop in Whitehall MI getting re-cored. The frame of the unused "oil" cooler between the CAC and Radiator provides baffling and support. I cut it out and will reinstall it. The core is steel and weighs about 50lbs. Dropping unused lbs is always a good thing.
Name:	ImageUploadedByAirstream Forums1433356495.444346.jpg
Name:	ImageUploadedByAirstream Forums1433356529.077177.jpg
Old 06-05-2015, 03:53 AM   #10
1995 36' Classic 36
Shop still has my radiator and CAC. They say they are both pretty thin and fatigued. Before spending big bucks on getting obsolete parts re-cored, I'm looking at alternatives. I can get a new pair that fit a Freightliner that will fit nicely and have more capacity. I'll have to fabricate mounting, baffling, and modify the fan shroud. It would be nice to have parts that are modern and readily available. Just about anything shaped like a barn door will fit back there.
Since dirt is an issue on these pushers I'll mount it such that the radiator can be removed separately with the CAC staying in place for cleaning.
Old 06-05-2015, 09:28 AM   #11
SebasSF's Avatar
Here you go: http://www.ebay.com/itm/Spartan-Moto...c96a84&vxp=mtr
Old 06-05-2015, 01:55 PM   #12
1995 36' Classic 36
Wonder if that's a scam? Looks like it parked at the factory. Engine and Transmission are worth well more that the asking price. Wheels and tires alone would be worth $5k.
Old 06-05-2015, 07:08 PM   #13
1995 36' Classic 36
Decided to weld up the leaks in the CAC and patch up the radiator. Got them back pressure tested and cleaned for $141. I'll get it together tomorrow and test drive it. There are quite a few options to replace them with readily available modern technology with some fairly minor modifications to the mounting and baffling. The cost would be less than re-coring the existing units. Performance would be better and about 50 lbs weight savings.
Here's the stack ready to go back in.
Name:	ImageUploadedByAirstream Forums1433552908.611151.jpg
Old 06-05-2015, 11:49 PM   #14
SebasSF's Avatar
It actually looks like it's for sale by Spartan, so probably not a scam.
I must be a Thread killer adonh Off Topic Forum 56 09-15-2014 09:10 PM
Rust on the end cap rivet line - deal killer? RhinoWW All Argosy Trailers 8 08-20-2014 07:55 AM
Killer Bee Airstream-Alaska, 1968! Randy Gates 1965 - 1969 Globetrotter 0 07-16-2011 05:38 PM
Battery Killer! What could it be? tjstew Batteries, Univolts, Converters & Inverters 14 02-22-2011 06:27 PM
