Old 01-17-2016, 04:59 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
TH-400 rebuild or new
Front and rear Oil seal are leaking on my TH-400 and I found a good amount of metal dust and a few small chunks (size of very small nail heads) in the pan when I replaced it recently. Someone also messed up one of the threats under the crossmember and did a fairly successful helicoil thread repair job, which appears to be holding.
Should I have the trans rebuild and just buy a new one?
I don't think I want to go with the 4L80E at this time, unless I would know someone that could deal with all the associated issues, especially the fuel injection.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 01-17-2016, 06:43 PM   #2
1973 31' Sovereign
Middletown , California
In general I think you are better off rebuilding what you have unless it had a catastrophic failure that tore up a lot of parts. Most of the time automatics quit working because of a rubber part like an O-ring or a seal. That is why trans oil temp is important, a little too much heat and the rubber parts harden and then you start burning up clutch plates and pretty soon your vehicle wont move. Most of the time a rebuild is just what is called "soft parts" gaskets and O-rings and clutch plates. If you have a good transmission guy he will know what "hard parts" will need to be replaced like gears or bearings. You have to trust the judgment of the re-builder weather you get an exchange transmission or get yours overhauled. I guess you just pay the money and hope the re-builder was good. To get the most life from your transmission just try to pull forward onto leveling blocks instead of backing on because reverse is a higher gear ratio than first and it is easier on the transmission to go forward. Leland
ijustlee is offline   Reply With Quote
Old 01-17-2016, 06:56 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
I would swap for a rebuilt unit with a good warranty
CRH is offline   Reply With Quote
Old 01-17-2016, 07:58 PM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Find a TH 400 specialist and have him rebuild yours. There are many clutches, bands and other parts from other transmissions that can be used to really build up the TH 400. Find a guy that really knows the TH 400 and have him build you a great trans.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 01-18-2016, 06:09 AM   #5
Peter, if you exchange you need to make sure you get the 475 version with the straight cut gears.
Or like the TBI you could go with the 4L80e and we can work out the bugs together
Old 01-18-2016, 12:13 PM   #6
1977 31' Sovereign
Lynnwood , Washington
The 4L80E is a good tranny, but it's computer-controlled: shift switches inside the side cover; torque converter lock-up solenoid; valve body (electronic shift control switch) ; electronic speedo output; etc. You may hafta relocate the cross member. And you'd also hafta shorten the drive shaft.
Frankly, the TH400 is a damn good transmission. Take it to an old-school tranny guy and let him build it properly for you - to your specs. The heli-coil can be heli-arced, drilled, and tapped. So that's no big deal.
BTW - I'm an old-school back counter Chevy parts guy and I'm skeptical of what's "new" out there. I'd much rather take it to a bona-fide tranny guy I trust and (at the very least) let him do a tear-down and get his opinion.
BTW - I'd go to an old-school, independent tranny shop. Today's dealership techs are a generation removed, and have no clue how to build a TH400.
If you're thinking "overdrive," research Gear Vendor. Their unit bolts directly to your TH400 case and thus, replaces your tail shaft housing.
Tom
TomKirk is offline   Reply With Quote
Old 01-18-2016, 01:24 PM   #7
2014 16' Sport
Walnut Creek , California
Are there any "Old school" TH-400 guys still out there? After all G.M stopped installing them in 1975. That's 40 years ago. Most are retired by now traveling in their Airstreams.
Elbo is offline   Reply With Quote
Old 01-18-2016, 03:46 PM   #8
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
LOL, if you can't find an old guy, try Jasper. Good work, good people, great warranty.
bobmiller1 is offline   Reply With Quote
Old 01-18-2016, 04:47 PM   #9
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
You might look into a prepped 700R4 it is used in a lot of street racers due to durability and performance.You will pickup a overdrive (4th gear) and that may be helpful in your application.Your turbo 400 was a good transmission but there have been some improvements since its introduction.
Old 01-18-2016, 05:32 PM   #10
Grosspoluter's Avatar
Franklin Park , Illinois
Rebuild
The trans on my 345 had a LARGE crack in the bell housing
I pulled a running trans out of another motorhome
That trans (I was told) ran fine (it was attached to a broken motor)
But I figured if it was out I might as well rebuild it I just brought it to a AAMCO trans place near me (I did some research and picked a shop near me with good reviews) then I had a truck repair shop pull the bad and put in the good I haven't taken any really long trips in it but I think I've put about 500 miles on it without a problum
Grosspoluter is offline   Reply With Quote
Old 01-18-2016, 06:04 PM   #11
airmack
1989 37' Airstream 370
Howick , Quebec
Th 400
Stay with a TH 400 one of the best ever made for our style of motorhome Malcolm
airmack is offline   Reply With Quote
Old 01-18-2016, 06:54 PM   #12
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The THM 400 was used in production vehicles through 1989, and longer in military Hummers.
Brevi tempore!
Old 01-19-2016, 06:48 AM   #13
1978 28' Argosy 28
Peter, I'd personally have it rebuilt by a reputable tranny shop. Same sentiment as many above. reputable, knowledgeable etc.. You might be hard pressed to find another TH-475, so I'd stick with what you have.
Keep us posted!
bpg_austin is offline   Reply With Quote
Old 01-19-2016, 08:48 AM   #14
belen , New Mexico
The trans is better than that 454 and worth the rebuild! Im just sayin
alantbird is offline   Reply With Quote
Turbo 400 tranny rebuild/upgrade option IPM Mechanics Corner - Engines, Transmission & More... 14 04-16-2007 07:18 AM
2,400,000.00 airstream bill benton Trailer Values 4 06-07-2006 07:54 PM
$400,000 Airstream Dbraw On The Road... 12 03-14-2006 04:59 PM
TH 400 Transmissions Bronze Dancer Mechanics Corner - Engines, Transmission & More... 1 02-17-2003 06:05 AM
