Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 04-25-2003, 07:58 AM   #1
cookieduster1
Profile:
Temperature Gauge
1987 Model 345 Motorhome
Temperature gauge has quit working.
Is there a source for a replacement?
Airstream says try Chevrolet.
Chevrolet is of no help.
Any suggestions?
Jim Cook
cookieduster1 is offline   Reply With Quote
Old 04-25-2003, 08:11 AM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Are you sure it is the gauge??
The other problem could just be a bad 12 volt feed to the gauge itself, the connectors on the back of the instrument cluster has given me trouble in the past. Disconnecting and cleaning has worked for me in the past.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 04-25-2003, 12:07 PM   #3
cookieduster1
Profile:
Thanks Brett G. I will check out the 12
volt feed.
Jim Cook
Old 04-25-2003, 08:45 PM   #4
FrankR
Profile:
Dash gages
I think the gages for Airstream are a GM item as all the other mechanical parts are. Mostly the temp gage will not read properly or not function because the sender has failed. The sender is very easy ti remove and replace if required. A very easy test for the temp and oil gage is to pull wire connector off sender and touch same wire to a ground. A ground is any metal part near sender. A helper or partner needs to be inside vehicle with key on but engine off. Historically the senders fail first. The gage will fail prematurely if the are poor battery, engine and body ground wires. It is impossible to have too many ground wires. The number one alternator failure is because of poor battery, engine and body grounds. The number one failure of starters is starting with battery not fully charged. Factory gages are of very poor quality. The information is often either hi or low by 20% compared to a quality gage.
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 04-26-2003, 07:19 PM   #5
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: Dash gages
I agree with Frank. GM gages are pretty reliable as in functioning. They may not be perfectly acurate but seldom do they outright fail. It's usualy a Sender or wiring problem.
Number one problem with GM Temp gage failure is the sender location. The wire often gets knocked off the sender when somebody is giving a tune up and fighting to get a plug wire off. Most GM V8's the sender is between Cylinders 1 and 3 in the head between the sparkplugs. It's somewhat blocked by veiw if you have the "Log" style A/C Compressor.
On most GM V8's it can be installed in 4 locations. Those are between 1-3, 5-7,2-4 or 6-8. Most GM heads are identical and will mount either side. I know that's acurate for the small block V8's and I'm pretty sure it holds truck for the big blocks as well.
I'm just learning the 454 and I will be working on mine tomorrow to fix a water neck leak and I'll let you know if I find any thing different on it. Mine is in a Suburban but These engines are assembled on a line and all the senders and stuff are installed well before it makes it to the chassis. They run on K.I.S.S. (Keep it Simple Stupid) mode of operation so very little deviates.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 04-26-2003, 07:50 PM   #6
74Argosy24MH
Profile:  LOST , Hawaii
Big blocks have 1 hole for temp senders per side, it is usually mounted on the left halfway down the head and will be higher than the sparkplugs/exhaust manifold and made of brass. Also look near the thermostat/radiator hose on the intake manifold.
John
74Argosy24MH is offline   Reply With Quote
Tongue Weight Gauge Bud Brown Towing, Tow Vehicles & Hitches 5 06-30-2007 04:38 PM
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 10:35 AM
Temp Gauge thenewkid64 Mechanics Corner - Engines, Transmission & More... 12 09-27-2003 08:43 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 09:54 AM
Refrig pressure gauge. caadoptees Refrigerators 5 07-08-2002 12:04 PM
