Not sure how this fits into the vintage scene, however, I have bought a trans gauge and sender from these folks. Got the order only a few days after ordering and fit, finsh and performance has been great.
Brett, I would think that there is an automotive division as they are so prevelant on all brands of MH's....qite possibly they are interchangeable as most inbourds and stern drives are altered auto motors....I will look for an 800 number...jem
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
Originally posted by thenewkid64 ....
Mine say teflex, but all the teflex stuff I find is for boats.
Mine has been replaced with a SW knockoff and the range is either wrong or I run at 150-160 degrees
Welcome to the teflex club.
Operating temp on my gauge shows 160 degrees. I took a laser heat sensor and found that it means 180 degrees.
Since I know that I am not very motivated to change the gauge.
My real operating temperatures are 180-200, which is where they should be.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
peter
is the error in the guage or the sensor??? i replaced the sensor and checked mine and it is now almost on the mark with the laser temp guage. if you have a 195 thermostat it has to show almost 200 to 210 if not the thermostat is not working. does that not make sence.
i played with my system this summer and i was confused . with thermostat i was seeing 200 to 220. with out the thermostat it never got over 180. i was considering not putting the thermostat back in the system. however i did and used a jug of super cool .
190 to 210 pulling the trail blazer.
i dont think i would replace the guage if knew what the error is. we drive cars with idiot lights . rather have a guage be it right or wrong it says more than a light. most time when the light comes on you just blew a engine. lol
al
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
Al,
I agree, whats the difference anyways.
Get to know your engines normal operating temperatures and note the adverse conditions. The sensor is only a 1 point reference. Take a laser heat sensor and you will freak, as you know. 500 degrees at the exhaust. Wow. Radiator 180, thermostat housing 195, cylinder heads 220, carburetor 170, my god the fuel is going to blow.
All we used to have is a needle with a red field which said "HOT"
Al is right on the mark.....finally got a response from an old buddy at the factory and he said if the guage works but gives the wrong reading, it is undoubtably the sender end that is munged up....jem
The Silver Buffalo
WBCCI # 14067
peter
i got mine from autozone. it was probably all luck that they matched. be careful and dont mar the new sensor if it isnt an improvement take it back. they are not that expensive. if i doesnt improve the problem dont eat it. got the 2 lb gas filter installed today. lol
al
AL
allison 6 speed
