Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 05-29-2002, 07:28 AM   #1
rdm
rdm's Avatar
Profile:
Tag axle shock
Has any one replaced the shock between the rear axle and the tag axle on a 325 or 345. Is this a special shock or can I match it at the local auto parts store.
Looks like my week for SHOCKS.
Ray
rdm is offline   Reply With Quote
Old 10-29-2006, 10:27 PM   #2
Howard Lefkowitz
Profile:
They are the same shocks as used on the trailers.
Howard Lefkowitz is offline   Reply With Quote
Old 11-07-2006, 09:12 PM   #3
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
You can get it at a parts store. I brought mine into AutoZone and they matched it perfectly.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 07-10-2008, 09:00 AM   #4
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
That shock is a horizontal shock.
It is only available from an Airstream dealer.
No auto parts store in the country would have that special shock. They may have one that looks similair, but they do not have that special made Airstream shock, as per the Airstream factory.
Vertical shocks, "will not" function correctly in a horizontal position.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 07-10-2008, 03:07 PM   #5
GreatPumpkin
GreatPumpkin's Avatar
Profile:  1964 26' Overlander
Colville , Washington
Images: 70
Andy - better check the dates of those posts - you're whistling in the wind...
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus."
GP
GreatPumpkin is offline   Reply With Quote
Old 07-10-2008, 04:25 PM   #6
Commercial Vendor
All goes to prove, once you become a senior citizen, you make mistakes, which are non taxable, since the feds recognize that your time is limited once you draw social security.
Inlandrv.com
800-8777311
Old 07-10-2008, 04:49 PM   #7
Pop Rivet
Pop Rivet's Avatar
Profile:  Salt Springs , Florida
Question Interesting
First, let me admit I know little of the engineering or design of shock absorbers but I'm don't understand why orientation would be a factor on their performance. Basically, are they not just a flow restrictive disk in a cylinder? some use fluid, some gas. Why would gravity matter?
Pop Rivet is offline   Reply With Quote
Old 07-10-2008, 04:53 PM   #8
Commercial Vendor
The valving is different.
Try using a bottle jack, lying on it's side, with the pump side on top as opposed to the bottom.
Nothing in life is as simple as we might like it to be.
Inlandrv.com
800-8777311
Old 07-10-2008, 08:15 PM   #9
GreatPumpkin
Images: 70
Give them a little time Andy, and they will figure out a way to tax you on it - and make you like it all at the same time
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
GP
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 11:37 PM
Tag axle brakes for 350 classic Marshall Walters Airstream Motorhome Forums 1 08-29-2003 06:42 AM
Tag Axle Oil Level? swebster Airstream Motorhome Forums 9 08-25-2003 06:01 AM
Tag Axle Brakes cooperhawk General Motorhome Topics 1 06-23-2003 01:48 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 09:47 AM
