Old 06-04-2014, 12:49 PM   #1
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
Tag Axle grease fitting
Does anyone know where to source the bearing buddy (I think thatís what it called) in the tag axle? It is supposed to aid in keeping the tag hub fully greased. Mine is cracked and grease comes out that crack as I pump it in through the zerk fitting and I don't believe the grease is getting into the bearing. Thanks, Steve
t7389sg is offline   Reply With Quote
Old 06-04-2014, 01:46 PM   #2
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
northern tool maybe..
MrJ is offline   Reply With Quote
Old 10-04-2014, 06:16 PM   #3
wxbuoy's Avatar
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Steve any luck finding a source of supply?
Dave and Felicia
wxbuoy is offline   Reply With Quote
Hensley Spring Plunger, Grease fitting spring bar retainer dznf0g Hitches, Couplers & Balls 2 08-29-2012 07:43 PM
Hensley spring bar grease fitting dmcummins Hitches, Couplers & Balls 6 10-11-2011 05:12 PM
Axle Fitting in Reno (NV)??? Yomster Axles 7 03-29-2011 03:03 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
Brakes grease and axle check tincanholiday Axles 2 09-03-2005 07:20 PM
