Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 02-23-2006, 10:39 PM   #1
ralley
Profile:  Prince Frederick , Maryland
Tachometer failure!!
Yesterday, on the 350, I was a good boy and replaced the plug wires, distributor cap, and rotor on my 454. The wires were getting a little grilled from heat. Now the TACH doesn't work. I made sure that I reinstalled the pickup around the # 1 plug wire, which I ASSUME is the tach pickup. The wires are new MSD 8.5 mm stuff, and I did not change the coil. Did I screw up, or just miss something?
Rob Alley
1991 AS 350
ralley is offline   Reply With Quote
Old 02-24-2006, 04:41 AM   #2
85MH325
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
That's a tough one. I don't know how different a '91 350 would be from an '85 325, but on my 325 the tach lead came off the distributor.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 02-24-2006, 05:44 AM   #3
Robfike
Robfike's Avatar
Profile:  Speedway , Indiana
The Tach lead should be one of the 2 plugs that plug into the distributor/coil cap. The cap will be marked "Tach" in the proper location.
Robfike is offline   Reply With Quote
Old 02-24-2006, 12:00 PM   #4
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Yup, tach lead is off the distributor. Mine had been "crimped" to another wire by a PO. I would occasionally loose connectivity and my tach would bounce around.
Check to make sure the 12V/Tach plug is well seated in the distributor and then start looking for loose connections. The wire runs in the bundle up the left side of the doghouse then up.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 02-24-2006, 05:19 PM   #5
ralley
Thanks all.
Strange--the distributor is a (presumably) 91 model electronic ignition with only a rotor and a 3 plug module under the cap. One plug is internal to the cap, and the other two go to the coil and elsewhere--I forget. If I have this right, I need to look for a wire going to the gage on the dash with a problem, coming from the module in the distribuitor. Please straighten me out if I have misunderstood---
Rob
Old 02-24-2006, 06:04 PM   #6
swebster
RivetAddict
swebster's Avatar
I am assuming you have a stock HEI ignition? There should be two plugs going into the distributor. The outer is a 12V feed and the tach wire. Looking down on the dust cover they are each labeled.
Steven Webster
AIR 1760
ThisOldRV.com
house batteries wb13798 Mechanics Corner - Engines, Transmission & More... 16 02-07-2006 07:41 PM
Marshall 250 regulator failure nickcrowhurst LP Gas, Piping, Tanks & Regulators 11 04-18-2004 07:08 AM
Rallies for M - F working class in SoCal GoldFever The Rally Zone 54 12-10-2002 11:54 AM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
