Old 05-11-2005, 12:06 PM   #1
1985 34.5' Airstream 345
Jarrettown , Pennsylvania
Synthetic vs. old-fashioned?
Hello all, have the 345 in for some adjustments and we are thinking about an oil change. I just read through Chaplain Kent's awful experience with same - consider myself forewarned! It is at a reputable truck center. Anyway, we have been discussing whether or not to use synthetic oil at this point, 69000 on an 86 345. Any strong feelings either way?
pbnjsellers is offline   Reply With Quote
Old 05-11-2005, 12:54 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
No strong feelings -
I made the switch to synth with about 10,000 miles more in the engine than you now have.....remember, the 345 is a heavy beast and the 454 COULD give up the ghost at any time - with or without synthetic oil.
Another thing to remember, oil life should be limited by a time interval as well as a mileage interval...a good arguement for Dino oil since it is a whole lot cheaper.
One of the things that caused me concern was the warning that using Synth in an "older" engine could cause some "oil weeping" at marginal seals - didn't have the first leak - but it didn't improve the gas mileage either.
I do run Synthetic in the rear end - was advised to wait until the tranny had about 10,000 miles on it prior to making the switch, but the new Allison trannies now come from the factory with non-Dino installed.
Luck
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 05-11-2005, 12:58 PM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I have used Valvoline synth blend, and now gone back to regular Castrol as an oil "review" I had read rated it very high.
Regular oil changes, proper warm up, regular use and care means a lot also to your 454's longevity.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-11-2005, 01:22 PM   #4
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
I run dino oil (Castrol) and just do the oil/filter change every 3000 miles. It's cheap and easy to do yourself. I also know that it's done right and I gets me under there to look at everything.
I've also taken to performing some routine "preventative checks" at each oil change. I pull each plug and check it for burn properties, while the plugs are out I perform a compression check on each cylinder, check the air cleaner, breathers, check the coolant levels, look for oil in the coolant, etc.
A little overkill for an oil change but with 186,000 miles on the coach and who knows how many on the motor it's cheap, simple preventative maintenance that might alert me to a larger issue before it becomes catastrophic.
Of course my wife wonders why it takes me two hours to do an oil change
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 05-11-2005, 03:44 PM   #5
LOST , Hawaii
Very good idea. Most "oil change techs" probably don't have a clue about anything under a vehicle other than the filter and drain plug, and as Chaplain Kent unfortunately discovered some are just clueless. Unless it is a glaring safety defect I doubt if you would even hear about any problem even if it was noticed. A lot of shops don't want to deal with a vehicle this old or large. If yours is a gas engine it will use a spin on filter, less chance of the wrong part. It is not a fun place to spend time, but one of those jobs that is the price of ownership.
I vote dino oil. Probably more important than the type is the time interval between uses. Even with the best of intentions these engines are not really properly used, they sit for weeks then haul 14,000 lbs. down the road. Daily use is better. Considering the price of synthetic oil and common rv usage, I would rather use cheaper dino oil and keep shorter oil change intervals.
John
74Argosy24MH is offline   Reply With Quote
Old 05-11-2005, 04:01 PM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
We've decided to switch to synthetic because of the low morning temps here in the winter. At -20 degrees, adequate lublication during cold starting would be nice.
Lynn
WBCCI 21043
Old 05-11-2005, 04:01 PM   #7
Craftsman
Guest
Posts: n/a
It seems that unless your engine is new or your running it at high temperatures for prolonged periods the price difference would be better spent changing it more often. It's my understanding that if you've been using a standard oil changing to synthetic will cause it to leak past the rings and you'll be burningthat price difference.
Old 05-11-2005, 04:55 PM   #8
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Lots of good oil information at http://bobistheoilguy.com
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-11-2005, 06:19 PM   #9
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I put penzoil synthetic in the jeep at 16k miles and have used it ever since. I change oil and filters every 5k. I have not had any leaks in the seals, but you are susposed to run one oil change interval before switching to synthetic so that the seals will properly seat. Right now the engine has 140 k miles on it. Is it worth the difference in price, no. Would I do it again, yes. Its a 92 jeep that has been garaged its entire life and I am passing it on to my grandson. I run dino in my 92 Cummins and in my 2001 town and country. I doubt that the chrysler will live as long as the jeep. Synthetic for engines that sit unused for long periods as well as cold start-ups.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 05-11-2005, 06:25 PM   #10
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I run Synthetic ( 100%) in my 5.7l Suburban, and am very happy with the overall result. My engine uses no oil now, ( used to burn a quart every 600miles) and runs quieter and smoother at startup. I use Amsoil, but do not believe in their 25000 mile oil change interval. I change my oil every 6 month or 9000 miles, whichever comes first. I will not go back to dino oil for this vehicle.
I costs me about $ 40.00 in materials, including their HD filter. I find this reasonable, in relation to the improvements that I noticed.
I do believe that it is of advantage, especially in an engine that is used in extra duty service such as towing or motorhome use.
Otherwise, all fresh oil is good oil......
Uwe
www.area63productions.com
Old 05-12-2005, 07:57 AM   #11
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Welp - I use synthetic and I change it every 3,000 miles............. I'm sure I'll hear about how crazy I am, but nothing is too good for my autos.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 05-12-2005, 08:06 PM   #12
Tinsel Loaf's Avatar
I use synthetic engine, transmission and differental. I noticed a two MPG increase after I started using synthetic lubricants.
Tinsel Loaf is offline   Reply With Quote
Old 05-12-2005, 09:15 PM   #13
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
The old 454 cubic inch in the motorhomes is one of the most overworked engines I am aware of and would benefit from the higher operating temperature of synthetic oil. However, if you use it fairly low annual miles, then it is expensive to use Syn. and change it because of time and not distance.There are partial syn oils on the market and they might be a good option for an older motor that works hard but, is changed due to time.
wingfoot321 is offline   Reply With Quote
Old 05-13-2005, 06:43 AM   #14
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Lynn
Depending on what vehicle you have, there is now a 0W-20 oil out there, it is pretty thin, even at very low temps.
Engine Oil Question ViewRVs Mechanics Corner - Engines, Transmission & More... 12 05-25-2008 08:45 AM
Synthetic Wheel Bearing Grease Pick Axles 4 11-24-2002 08:18 PM
Cleaning hubcaps Dave-O Wheels, Hubs & Bearings 1 11-22-2002 05:34 PM
Squirrel Eating Gas Lines! lbrodsky LP Gas, Piping, Tanks & Regulators 8 07-06-2002 10:03 AM
Synthetic lubricants rdm Mechanics Corner - Engines, Transmission & More... 6 05-24-2002 04:28 PM
