Old 07-17-2005, 08:16 AM   #29
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
another vote for Mobil 1
I converted to Mobil 1 on the third oil change on the 2005 2500 Burb. I use Chevy's oil change "gage" to guide my changes.
Abe
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 07-17-2005, 12:05 PM   #30
The best oil is a freshly changed one...
I use Chevron Delo 400 15w40 or whatever heavy-duty diesel truck oil I can find, also 15w40.
I use the best filter I can find, NAPA gold, extended size. More oil. Or Purolator Pure one.
This is in 7.5L towing vehicle. It's not new to say the least, so I don't think it warrants synthetic. On the other hand, if my TV was under 5 years old - and I drove it more than 5K miles /year, I think I would use synthetic.
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
ipso_facto is offline   Reply With Quote
Old 07-17-2005, 12:58 PM   #31
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by 16595
I have switched all vehicles to Mobil 1, based to a fair extent on the following study: http://neptune.spacebears.com/cars/s.../oil-life.html
I feel that the synthetic will provide a cooler running engine which is pretty important in a tow vehicle. The above study seemed to favor the Mobil 1 over the Amsoil, in part because Amsoil seemed to develop a higher viscosity with age.
I expect I will switch the Suburban to syn trans fluid soon. Any comments? What brand do other use? I haven't seen Mobil 1 trans fluid.
My change intervals have been in the 8-10,000 range. If the mfgr says 7,500 I expect that is conservative in their view. The study says it almost never needs changing IF some makeup oil is added due to filter change. My '91 Cad uses a little oil and the suburban very little. I do a filter change at 5,000 and then change oil at 10,000.
Dwight
Nebraska
So just add 0W-30 to offset the thickened viscosity as the oil get older. You can't dismiss the fact that the Amsoil showed less wear in the engine in this study. That is what I would be interested in. I use the dual bypass system, change full flow filter at 5,000 miles, add a qt. of 5W-30, then change both filters and oil at the 10,000 mile mark. Always seemed to work for me.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-18-2005, 09:23 PM   #32
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
Your bypass filter the onr that use TP in it? I have seen it used. thay said it works. I don't know, I have heve used it.
alfalsetto is offline   Reply With Quote
Old 07-18-2005, 09:31 PM   #33
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
0W30 is just as thick as 5W30, 10W30 and straight SAE 30W oil at 100 deg C. The number before the "W" denotes viscosity below something like -20 F. Oil is never "thin enough" at startup on a cold engine.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 07-19-2005, 02:43 PM   #34
2005 31' Classic
Gretna , Nebraska
The study noted above seems to question this, as they found the greatest increase of suspended metals in the first couple thousand miles after an oil change. Check the study for a more accurate report than I remember here.
Dwight
16595 is offline   Reply With Quote
Old 07-19-2005, 04:36 PM   #35
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Dwight
I'd say that the detergents in these oils are probably most active during the first few thousand miles.
Uwe
www.area63productions.com
Engine Oil Question ViewRVs Mechanics Corner - Engines, Transmission & More... 12 05-25-2008 09:45 AM
Synthetic Wheel Bearing Grease Pick Axles 4 11-24-2002 09:18 PM
Cleaning hubcaps Dave-O Wheels, Hubs & Bearings 1 11-22-2002 06:34 PM
Squirrel Eating Gas Lines! lbrodsky LP Gas, Piping, Tanks & Regulators 8 07-06-2002 11:03 AM
Synthetic lubricants rdm Mechanics Corner - Engines, Transmission & More... 6 05-24-2002 05:28 PM
