Old 11-14-2006, 04:29 AM   #1
Surging Generator
I went to look at a 1982 310 last week, the unit on a whole was very nice. While testing the a/c units I noticed the generator seemed to surge while running, and the a/c units followed. Both units were on at the time. Was the load to high? The gen is an Onan 6.5k. Is this a normal occurance or should I be worried.
Thanks Joy & Mark
Alumi-Naught is offline   Reply With Quote
Old 11-14-2006, 04:54 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
6.5 should be anough to run both A/C's, although if they both start at the same time the startup surge will be very close to the genset's capacity. Sounds like the carb needs adjustment.
Old 11-14-2006, 05:28 AM   #3
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Joy / Mark, had the unit been sitting for a while? Does the fuel pull from the same line as the engine?
I just got mine back from a major service including a new starter and couldn't get it to suck up enough fuel to run for more than a minute. As I'm on the same line as the engine I just cranked up the motor and ran it for a minute to pull fuel into the line. The rig had not been run for over a week....
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 11-14-2006, 05:44 AM   #4
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
I'm with Terry - carb adjustment. They will "hunt" or "surge" when the load exceeds the current output then drop when it revs up...the idea is for the engine to put out as much as is being called (does that make any sense at all?) It's likely you'll need some basic service on the generator but it's good that it runs.
One note, don't run the ACs with the generator surging. It can vary the voltage/amps dramatically and damage the internals of the AC units.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 11-14-2006, 08:38 AM   #5
wascobob's Avatar
wasco , Oregon
My 6.5 Onan had a bad case of the surgies---The cure was new plugs, points and condenser and then a slight adjustment of the carb. main jet.
Carefully set the point gap per your manual---If the point gap is set correctly, then the timing is also set correctly. In other words the point gap sets the timing (this is a critical adjustment).
Mine runs happily now.------Bob
1988 Classic 290 motorhome
wascobob is offline   Reply With Quote
Old 11-14-2006, 10:07 AM   #6
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
These are all good points. Not as common, but the governor may be out of adjustment as well, sometimes from worn linkage, sometimes other issues.
Bottom line, it should be fixable without too much $$, you'll need to get it to a shop.
Fyrzowt is offline   Reply With Quote
Old 11-14-2006, 02:08 PM   #7
Thanks to all for responding, this issue was one of the hurdles before we decide on this 310, We flew to Texas to look this one over last weekend. Did not find any major problems, everything seems to work fine, We did find some minor finish issues hopefully this can be cured with a good wax and buff (should I be concerned about this? it is an 1982), all accesories are there including the blender and kinfe sharpener. If we can just make up our minds I will propably fly back over Thanksgiving weekend and drive home. You all have been a great source of info.
Thanks Again
Joy & Mark
Old 11-14-2006, 06:18 PM   #8
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
Sounds like a great machine. I look forward to seeing some pictures.
Rob
Robfike is offline   Reply With Quote
Generator filters ViewRVs Mechanics Corner - Engines, Transmission & More... 7 04-05-2004 08:17 AM
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 05:31 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 08:51 AM
Take this Generator and Stuff It..... kzener40 General Motorhome Topics 8 07-24-2002 07:30 PM
