Old 04-15-2011, 06:28 PM   #1
1982 28' Airstream 280
Redwood City , California
Stumped by power steering
Well, I've finally been stumped in getting engine parts for the '82 280 and it is something as simply as the power steering reservoir hose or also known as the suction hose. This is the hose between the power steering reservoir and the power steering pump. I've been to multiple part stores so far. There are three issues...inside diameter of this hose is 3/4, must use hose rated for hydraulics (power steering fluid will eat through radiator hose, it is about 9-10 dollars a foot and typically comes in 10 foot lengths and no one has it.
I'm not quite sure but I'm guessing the hose on there now is heater hose and that is why it leaks like a sieve.
And did I mention that this hose is difficult to get to to change?
Anyone else been able to find this hose? Its a filler hose so no pressure in it. It is simply hose clamped on at both end.
Dean
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 04-15-2011, 06:57 PM   #2
r carl's Avatar
Lin , Ne
How many feet do you need?
100R16 Hydraulic Hose 3/4" | eBay
Old 04-15-2011, 07:41 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
We had the same hose to the reservoir on our '95 Chevy van. You can get it from Chevy, or even a hydraulic supply store. There's even one right down the street from where you live:
http://www.aaa-rents.com/hydraulic-hoses.asp
Old 04-15-2011, 07:54 PM   #4
Great option! Thanks!
Old 04-15-2011, 08:01 PM   #5
Awesome! Thanks! Yes this is just on the other side of town. I'm heading down there tomorrow morning to see what they get buy the foot. On their hoses page on their website, they even mention "suction" hoses. Hopefully less expensive since there is no pressure in this line.
Kohlweiss auto parts in town wants $100 for a 10 foot hose. Can't get myself to spend a 100 bucks on this silly hose!
Dean
Old 04-15-2011, 08:02 PM   #6
Price is a lot less then $9-10 per foot!
Old 04-15-2011, 10:49 PM   #7
Smartstream's Avatar
Port Angeles , Washington
Check out this place Discount Hydraulic Hose.com They have everything you need at a reasonable price, $20 minimum order. I got all the hose and fittings to redo my leveling jacks system from them. Cheers, Dan
Smartstream is online now   Reply With Quote
Old 04-16-2011, 07:54 AM   #8
That's another great site. Thanks!
Old 04-19-2011, 10:25 AM   #9
Great Info, and I need to do mine judging by the dropping levels and big stain under the M/H.
Questions:
1/ As you talking about the pipe between the fill reservior and P/S pump, and how long is it?
2/ There is a return line too... anyone know what size and length that is?
Old 04-19-2011, 10:49 AM   #10
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Good idea to check the front PS hoses for leaks. One of mine leaked out the fluid and the reservior got hot, hot hot!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-20-2011, 12:40 PM   #11
With the huge PS and Hydroboost load on the fluid, is there a cooler plumbed in as standard?
My Suburban has one, just a simple "S" shaped tube in front of the radiator/condensor.
I dont remember seeing on on my AS...
Old 04-20-2011, 12:54 PM   #12
1977 Argosy 24
Milltown , Wisconsin
Another option is a John Deere dealer, The ones that sell and service farm equipment not the lawn mower guys. They can makeup any size hydraulic hose you could ever need and have all the different ends in stock. I am sure they have just the hose you need.
ventport is offline   Reply With Quote
Old 04-20-2011, 01:41 PM   #13
Mike Leary's Avatar
Images: 11
My files show I had both my power steering hoses re-moved, re-newed and re-installed for around $250.00 with labor. That included flushing the system and fresh fluid. Hoses were around $50.00 ea. to be re-manufactured, so $150.00 in labor. I watched the tech working on them, it was not a chore I was interested in taking on.
Old 05-29-2011, 11:38 PM   #14
Got 5 feet of hydraulic hose from Discount Hydraulics at about $5 per foot...half price of anywhere else.
Took many hrs today to replace...what a pain. Problem has getting old hose off of pump. Also the hose they sent me has a metal wire inside the hose for strength. Problem is can't expand hose any to push over rib on connection on pump. I don't suggest this hose at all.
Folks don't understand that this hose has no pressure on it just needs to be hydraulic fluid rates so that it doesn't deteriorate from fluid. Everyone insists on selling you hose rated for 300 lbs pressure. Rolling my eyes!
I had to rip out the metal wire from an inch of hose at the end to be able to push onto pump.
Got it all back together but now have squeak in pump. Maybe air in line/pump. Well have to move mh off current space tomorrow.
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 39 08-08-2018 10:58 AM
1978 Argosy Steering Gear Leak stereoeric Argosy Motorhomes 3 09-05-2011 11:38 PM
120 volt outlets from battery power? etobolski Electrical - Systems, Generators, Batteries & Solar 4 04-05-2011 02:15 PM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
Power cord length-recommendations? SilverHoot Electrical - Systems, Generators, Batteries & Solar 17 01-23-2011 02:39 PM
