Old 05-30-2011, 01:57 AM   #15
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Originally Posted by dadstoy View Post
Got 5 feet of hydraulic hose from Discount Hydraulics at about $5 per foot...half price of anywhere else.
Took many hrs today to replace...what a pain. Problem has getting old hose off of pump. Also the hose they sent me has a metal wire inside the hose for strength. Problem is can't expand hose any to push over rib on connection on pump. I don't suggest this hose at all.
Folks don't understand that this hose has no pressure on it just needs to be hydraulic fluid rates so that it doesn't deteriorate from fluid. Everyone insists on selling you hose rated for 300 lbs pressure. Rolling my eyes!
I had to rip out the metal wire from an inch of hose at the end to be able to push onto pump.
Got it all back together but now have squeak in pump. Maybe air in line/pump. Well have to move mh off current space tomorrow.
Sorry to hear you had problems. In the hydraulic industry all suction hoses come with wire or some other reinforcement to prevent the hose from collapsing and starving the pump. This goes for water hoses too. Your lower radiator will have reinforcement too. Glad to hear you got it working.
Cheers, Dan
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
1978 Argosy Steering Gear Leak stereoeric Argosy Motorhomes 3 09-05-2011 11:38 PM
120 volt outlets from battery power? etobolski Electrical - Systems, Generators, Batteries & Solar 4 04-05-2011 02:15 PM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
Power cord length-recommendations? SilverHoot Electrical - Systems, Generators, Batteries & Solar 17 01-23-2011 02:39 PM
