Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 09-08-2002, 02:48 PM   #1
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
Steps Opening And Closing For No Reason
GOT A GOD ONE THIS WEEKEND MYSTEP OPENS AND CLOSES FOR NO REASON .. WHEN I GO UP A HILL THE STEP OPENS AND WHEN I GET OVER THE HILL IT CLOSES . IT IS VACUUM RELATED JUST DONT KNOW WHERE TO START/// ANY ONE EXPERIENCE THIS PROBLEM OR IDEAS AS WHERE TO START??? GIVING SOME SERIOUS THOUGHT TO REPLACING WITH AN ELECTRIC STEP, YOUR IDEAS ON THAT ONE??
wb13798 is offline   Reply With Quote
Old 09-08-2002, 03:29 PM   #2
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Step
You probably have a vacuum leak somewhere. I had a similar problem with a former truck where all the doors in the air vents would slam shut going up a hill and then open again coming down the other side. Turned out to be low vacuum.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 09-08-2002, 05:31 PM   #3
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
check the hoses for leaks around the step activator switch. By the way are you sure the steps are coming out, or is the warning light just coming on? Mine does that every so often, hitting a big bump for example.
Old 09-08-2002, 05:57 PM   #4
wb13798
wb13798's Avatar
th wife verified that the steps were out when the light was on. plus they went in and out so much they have a squeek now.
i have lok at the parts under the steps and dont see anything loose.
Old 09-08-2002, 06:29 PM   #5
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
it's your switch in the door frame. Pull it out, take it apart carefully and clean it real good.
I had the same problem. New switches are still available. I got mine from Inland for $30.- something.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 09-09-2002, 09:25 PM   #6
wb13798
wb13798's Avatar
looked at the switch tonight and the ohm meter reads 28 meg ohm with door open and one ohm closed , it is an electrical switch that is riveted in the door jam, i did find a wear hole in the aluminum plate that the switch plunger sits on when door is closed . flipped the plate over . strange that the switch plunger would wear a hole in the plate. will find out tomorrow when we go to onan to get the generator tweeked.
Old 09-10-2002, 06:30 AM   #7
PeterH-79MH
Profile:
Images: 63
The constant movement of the door while driving, rubbed the hole in the plate. Driving uphill, gravity pulled the door back just enough to disengage the switch.
The blinking door light (without the step coming out, like Alansd mentioned), could be the mercury switch, if so equipped.
I tilted mine a few degrees more, to eliminate that problem.
Now, the light only comes on when it is supposed to.
Old 09-11-2002, 07:21 AM   #8
wb13798
wb13798's Avatar
looks like the switch was the problem. lite didnt blink at all . the plate i mentioned is a bit over an 1/8 inch thick. thnx for the help..
Old 09-11-2002, 04:53 PM   #9
ALANSD
Peter- makes sense about the light switch. Mine blinks when I hit a really hard bump. Not often enought to be a bother, though.
Old 10-14-2002, 10:07 AM   #10
wb13798
wb13798's Avatar
2000 miles and no problems . thanks for the help it was a simple fix that i would never looked at as the source for the problem..
/////ive been told two heads are better than one, must be true../////
Old 07-01-2005, 10:03 PM   #11
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
Knowledge base really works
This three year old thread just helped me solve a problem wherein my automatic vacum powered step would no longer retract
Many thanks
guy99 is offline   Reply With Quote
Old 07-02-2005, 08:11 AM   #12
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
Let me ask further on the electric step question posed in the beginning. My step wobbles and does not extend to a distance I find comfortable. I have adjusted my step so that it is extended to its fullest length and use a stabilizer after we are parked. Since I use a cane for mobility and stability a wobble does not help plus I need extra room. Has anyone replaced our steps with an electric, or anything else that they like better?
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://www.fuzzytravel.com/grandakent/
Chaplain Kent is offline   Reply With Quote
Old 07-02-2005, 08:50 AM   #13
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 144
ELectric Steps Standard
Originally Posted by Chaplain Kent
....Has anyone replaced our steps with an electric, or anything else that they like better?
The 1987 345 came with electric steps as standard equipment - don't know what year Airstream made the switch from vacuum to electric.
Dennis
WBCCI # 1113
AirForums #1737
Old 07-02-2005, 12:43 PM   #14
GlenCoombe
GlenCoombe's Avatar
Profile:  Sumter , South Carolina
My '84 has a Kwikie Two Step.... needs to find a spot to use a com-a-long to bend it back into place... seems someone was backing up with the steps down and as a result they don't retract all the way up. Just another item on my 2-do list.
Glen Coombe AIR #8416
1984 28' Funeral Coach
Golf Professional Sales Rolling Showroom
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
