Old 07-07-2017, 12:50 PM   #1
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Stepping it up
So, I did a search here for motorhome step replacement and the results are erratic at best.
The Vacuum steps are OK, but I think electric may be the better way to go.
Is there a quick answer for the best brand, type, and number of steps for a 84 Excella Motorhome?
Wayne
WayneG is offline   Reply With Quote
Old 07-07-2017, 01:23 PM   #2
1989 34.5' Airstream 345
Ebro , Fla Panhandle
I checked my manual from. Kwikee, it is manual #874.
Best I can interpret is that mine is a model 40 series step.
It is 24" wide. Two steps. And close to 61/2" tall when retracted.
Their ph # 503-836-2126. At least that was in the early 90s
Good luck in your Quest.
Cheers Richard
tevake is online now   Reply With Quote
Old 07-07-2017, 01:37 PM   #3
WayneG's Avatar
Scotia , New York
Cheers Richard
I guess it has been a while since I last searched for steps.
I could have sworn the top end steps were $400 or less 5 years ago.
Best I can see on these is just under $500
Old 07-07-2017, 02:26 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Just a reminder that your step activation switch will have to be changed to open or closed pole (I can`t remember which). Brad or John will know. You will know when you install the steps and they open when you closed the door and retract when the door is open.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 07-07-2017, 02:59 PM   #5
WayneG's Avatar
Scotia , New York
Cheers
Tony
If I go for the upgrade, I will probably install a relay and run a new wire for powering the motor. Since the original wiring was there to only handle a solenoid, it may not be heavy enough to do a motor.
I also will need to find out if the new steps have a Retracted/Extended switch for the dash light
Old 07-07-2017, 04:12 PM   #6
Wayne, I replaced the vacuum steps in my old 310 with a Kwikee double step. Here's the thread on the 310 electric step replacement.
Here's a link to the steps I bought but the price has gone from $356 to $520, Kwikee 44-1662 double step. My guess is you can find them cheaper if you look.
The conversion wasn't difficult, the main problem I had was the wiring on the door switch. I made an assumption that the switch was a grounding type of switch when in reality it was supplying 12 volts! Steps were operating backwards when the ignition was on
I installed these same steps on my Argosy although it was a much more extensive job to get them to fit properly.
Old 07-07-2017, 04:14 PM   #7
The step controls are built into the step. The only thing you don't get is the light on the dash. For my Argosy I purchased a prox switch and have already added the light on the dash. Just need to connect the wires.
Old 07-08-2017, 04:13 AM   #8
WayneG's Avatar
Scotia , New York
Jeez for $500 you think they would give you a sensor for being retracted!
They should also give you options for the door switch so you dont have to screw with the wiring. Not that is is to hard to do.
One last concern, with modern parts that are usually made lighter weight;
It shows the weight limit as 300 pounds. I am usually 220 (down to 205 after surgery) I carry my sound gear up and down the steps all the time and some of it is 100 pounds.
Do the electric steps look as beefy as the original vacuum steps?
Old 07-08-2017, 05:26 AM   #9
Or at least a signal wire that you could connect a light to.
They do provide a small stick on magnetic switch to use but I opted to use the switch in the door of the 310. Thinking back on it I may have also had to replace the door jamb switch with one that had the the correct contact arrangement. I don't remember if it was a NO or NC switch.
My recollection of the steps is they are stouter than the original vacuum steps. The issue I struggled with on my Argosy was providing a rigid mounting platform. The Argosy framework is completely different than a 310 or 345. When I installed the one on the 310 other than drilling two (or four?) new holes I had to provide a gap filler because the top of the step assembly was narrower and there was about a 1-1/2" gap between the top frame and the bottom of the door jamb.
Bottom line is I felt the new steps were stronger than the old and seemed much more stable.
I've not used the ones on my Argosy since I installed and tested them. I've left them retracted during all of my rebuild.
Old 07-08-2017, 09:43 AM   #10
WayneG's Avatar
Scotia , New York
If they were still in the $300 range I would go for it but I dont see $500 being worth it.
I went to their website and it is useless to compare various models and features. If they cant get their chit together online, I cant trust that they make a product I want to buy.
Unless there is a good sale, I guess I will live with the quirky vacuum steps for now. It is like a extra engine vacuum warning when the step light comes on going up hill!
Thanks for all the help
Wayne
Old 07-09-2017, 04:52 AM   #11
It would be interesting to know why the price jumped from a little over $300 to over $500.
I had no choice on my Argosy and had to do something because the steps were a twisted mess. I did the 310 just so it wouldn't feel left out when I did the Argosy
Old 07-09-2017, 05:07 AM   #12
WayneG's Avatar
Scotia , New York
I notice the Kwikee is now under the name Lippert. Maybe that is where the extra $200 is going? Love corporate takeovers!
Anyway, for my 24' 77 Argosy, its steps were badly twisted and 2nd step missing. I straightened what I could and the missing parts I got from someone in Florida who apparently stockpiles parts. I dont have any notes on the contact info. They were very reasonable.
Old 07-09-2017, 10:02 AM   #13
Someone's got to pay for the takeover
I'm surprised your 77 has vacuum steps. Peanut is a 77 and it had the same steps that were on mine which are made from steel, unlike the trailers of the era which were aluminum.
Old 07-09-2017, 01:52 PM   #14
WayneG's Avatar
Scotia , New York
Sorry, they were manual steps.
Sold the Behemoth, stepping down as Mod... 85MH325 Off Topic Forum 39 10-03-2006 06:54 PM
