Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 07-13-2003, 11:59 AM   #1
The Hawk's Lair
cooperhawk's Avatar
Profile:  BACK WOODS , Minnesota
steering stabilizer
I removed my steering stabilizer from my 1984 motor home today. I prepared for the worst based on reading all the posts. I purchased both size pickle forks from Advance but neither was the correct size. I found by heating the steering arm with a torch and then using a 3/4" open end wrench with a pipe extension on the location above the taper finally broke the taper loose. Beating on the nut and using a wrench without the extension did not work. I needed the two foot pipe extension to have enough leverage.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 07-13-2003, 05:33 PM   #2
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 231
Never-Sieze It
Make sure you use a dab of Never-Seize or equivalent on all nuts and mating surfaces, all repairs have a way of haunting you, and Guess Who will probably be the one pulling it!
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 07-17-2003, 11:34 AM   #3
Profile:
Thumbs up removing tapered things
I find if one wacks the taper receiver, i.e. steering arm, (in the case of ball joints, the spindle) so as to "distort the taper" it helps (hitting on the side, if the taper is up and down ) this works extreamly well if one has an "air chisel" using a blunt round punch.
then using the blunt punch on the end of the threaded shaft, I like to keep the nut on as it kinda keeps the air punch centered ,also it keeps it from hitting you or "things" when it comes loose.
later, ol'George
George is offline   Reply With Quote
Old 07-17-2003, 05:37 PM   #4
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
I had a heck of a time getting mine off, but it was well worth the effort as the new Bilstein I installed makes the steering feel tight and more responsive on waffly roads. Never had much kick back before but the old stabilizer was mushy and worthless...probably was the original as it was a Delco.
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 07:03 PM
steering stabilizer ALANSD Mechanics Corner - Engines, Transmission & More... 30 05-08-2004 02:14 PM
Re: steering Orland Dewey Airstream Motorhome Forums 0 11-24-2003 05:02 PM
Steering gear box Orland Dewey Airstream Motorhome Forums 4 11-13-2003 08:12 PM
Improved Steering for windy roads scotta Airstream Motorhome Forums 3 04-01-2003 11:42 PM
