Old 05-07-2019, 09:29 PM   #1
Magnet18's Avatar
Churubusco , Indiana
Steering centering
Anyone seen this setup before? Is it part of the steer-safe system?
It's a simple system of two springs that work to pull the steering back to center. Previously it connected with one U bolt around the knuckle and a hole that went over the lower ball joint. The newer ball joints don't stick up as far, and therefore it won't mount to them, as it just pops off.
It wouldn't be a hurculean effort to come up with new brackets, but I'm wondering if it's worth the trouble.
ID:	340077   Click image for larger version
Magnet18 is offline   Reply With Quote
Old 05-08-2019, 08:58 AM   #2
Looks like it to me.
Old 05-08-2019, 09:54 AM   #3
I've heard nothing but good about the Steer-Safe units. Would it be possible to take the old ball joint to a parts house and see if you can find a suitable replacement?
bkahler is online now   Reply With Quote
Old 05-08-2019, 02:15 PM   #4
Magnet18's Avatar
Looking at the steer safe website, it seems they have changed the design since whenever they sold mine (probably the same time as the motorhome by the looks of it)
http://www.steersafe.com/install_fil...figure%201.doc
They now also use a U bolt around the ball joint nut, and it looks like a J bolt on the far side. That seems much more secure than the system I have held on by a single U bolt.
Normally I'd buy a new one as mine is clearly pretty crusty, but $500! I'll take another look and see what I can do with a welder and a trip to the hardware store.
1983 Airstream 310 Class A Motorhome
-Rob
Old 05-08-2019, 02:26 PM   #5
Magnet18's Avatar
I sent an email to steer safe and asked if I could purchase just the wheel brackets without re-purchasing the whole system, we'll see what they say
-Rob
Old 05-11-2019, 11:55 AM   #6
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey,
It's worth keeping. When and if you ever get a blowout, you'll be thankful you did. Mine has a u bolt, that goes thru the bracket. Should be able to get a u bolt
Get a heavy duty u bolt. They are a little thicker than a small muffler u bolt. I think granger has them. It has no affect on the steering either. I can't tell it's there. Even turning, there's no feeling of harder steering. DJ
davejay is offline   Reply With Quote
Old 05-12-2019, 05:20 AM   #7
Magnet18's Avatar
Thanks DJ!
I did decide I'm keeping it, steer safe sells the wheel brackets for $90 a piece. I was set to modify the existing ones but time is short so the wife encouraged me to just buy them so I don't work myself to death.
-Rob
Old 05-12-2019, 06:22 PM   #8
Hey,
I noticed your bump rubber is cracked. On my 85 325 the rubber is a block style as opposed to that triangle style. It seems to be more durable. Also these old things are 35 years old. I suppose that triangle style is good to . It does appear, the block style I got, has less travel space than yours. I think the block style actually is kind of a helper spring. Just a thought. DJ
Old 05-13-2019, 08:32 AM   #9
Magnet18's Avatar
I have new bump stops ready to go in. The replacements I ordered were the same shape as the original. I didn't know there was a square type, good to know, thanks
-Rob
Old Yesterday, 12:20 PM   #10
Magnet18's Avatar
New brackets showed up and I got them installed this morning
They went from one U bolt, to 2 U bolts and a J hook, wonder if they were having issues whth the old design
-Rob
« Electrical draw | Top | - »
"Centering" Brake Backing Plate Al and Missy Brakes & Brake Controllers 22 12-27-2014 11:54 AM
steering stabilizer ALANSD Mechanics Corner - Engines, Transmission & More... 34 04-01-2014 09:48 AM
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 06:03 PM
Improved Steering for windy roads scotta Airstream Motorhome Forums 3 04-01-2003 10:42 PM
GM option--4 wheel steering Kistler Our Community 4 01-08-2003 02:30 AM
