Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 02-15-2003, 03:51 PM   #1
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Starter heat problems
My starter heat problem included some "heat soak" slow starting. I replaced my starter when the solenoid burnt, and a few months later the new one did the same thing. This time I used a solid aluminum cased starter and solenoid, with a mounting block of billet aluminum that allows you to rotate the starters head away from the heat source. I then wrapped the starter in a thermo-tec jacket and the wires in their thermo tape. Hope this does the trick. The combo phot shows the old starter burnt, the new one mounted, the wrap on it, then the wires wrapped. Check out the aluminum block mounting the starter to the flywheel cover. Inch thick solid billet.
Why do I carry a spare starter? PeterH-79MH Mechanics Corner - Engines, Transmission & More... 31 07-07-2005 11:05 PM
Refer heat / venting JaceBeck 1999 Safari 3 08-21-2003 09:40 PM
Ode to a starter ALANSD Mechanics Corner - Engines, Transmission & More... 9 01-07-2003 11:55 AM
Heat protection ALANSD Airstream Motorhome Forums 14 11-03-2002 03:55 PM
Heat Riser ALANSD Airstream Motorhome Forums 7 09-11-2002 04:38 PM
