Old 02-11-2007, 05:58 PM   #1
76 Argosy 28' MH
john roeder's Avatar
1975 28' Argosy 28
Springfield , Ohio
Stabilizer shock
Need to replace this shock-steering stabilizer, it's leaking. Just wondering about the end that goes into the frame. I can't find a way or even see the nut because of the frame work. Is it welded to the frame so all you have to do is screw the old out and the new in. Also the other end sure is hard to get out but i will get, never give up. Thanks to all.
John
ID:	32233   Click image for larger version
Chief 1, You light em = we fight em
john roeder is offline   Reply With Quote
Old 02-12-2007, 03:55 PM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
John,
Not sure of your model, but typically there is an access hole on the back side of the frame where the nut is located. If so, use a socket with extension with an impact wrench if you have one. Hope that helps...
Dave
Fyrzowt is offline   Reply With Quote
Old 02-16-2007, 05:42 PM   #3
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
Bilstein makes a great replacement unit for these.
Rob
Robfike is offline   Reply With Quote
Old 03-07-2007, 11:50 AM   #4
Bilstein Part Number?
Anyone have a part number for a Bilstein stabilizer shock for a 1975 Argosy 20 350 engine? Thank you
911rs is offline   Reply With Quote
Old 03-08-2007, 07:53 AM   #5
Robfike's Avatar
Spencer , Indiana
Go to Bilstein Shocks, Edelbrock Shocks and more: eShocks.com They show the part number as BE3-2645-H0.
This is only one of the online shock outfits. I replaced all of my shocks and the steering stabilizer with Bilstien. (Except the tag shocks, they have to come from Andy)
Rob
Old 03-08-2007, 08:43 AM   #6
Thank you Rob.
Old 03-09-2007, 06:01 AM   #7
Robfike's Avatar
Spencer , Indiana
911RS,
Does your online name mean you have a 911RS? I road race a 911 in GT-3 class, and drive a '76 912E on the road.
Last summer I had the 345's hitch upgraded to be able to tow the race trailer. (7000#)
Rob
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
Shock absorber information Nye Thatcher Shocks 0 02-16-2005 10:49 AM
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 06:03 PM
63 TW shock Moonshot Shocks 5 08-26-2002 09:24 AM
Temps in the Freezer/Frig??? tenrsingr Refrigerators 38 05-31-2002 03:34 PM
