Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 03-13-2010, 09:11 AM   #21
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Definitely replace all the fuel filters. My rig has three, one at the rear pump, one under the step, and one in the carb at the fuel inlet.
But, if you heard backfires, I'll give odds your problem is ignition.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 03-13-2010, 09:13 AM   #22
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Sorry your trip was cancelled.
Check (replace) your vaccum lines. The spark advance/retard may not be working. When you put the pedal to the floor is sounds like flooding or ignition bad timing. Have the carb inspected look under the cap for signs of arcing. A fuel filter will cause a sluggish response. However it usually does not cause backfiring.
Michelle TAC MT-0
Sarah, Snowball
Old 03-13-2010, 09:24 AM   #23
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
I'll jump in on the cap roter combo. Chevy's HEI seem's to be prone to roter/cap failure. Your symptems seem ignition to me,not fuel. Adios, John
Diesel1 is offline   Reply With Quote
Old 03-13-2010, 09:32 AM   #24
Kmpro
kmpro's Avatar
Lubbock , Texas
My $ .02 worth. If it sputters under 45mph=Ignition. Over 45mph usually fuel.
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
kmpro is offline   Reply With Quote
Old 03-13-2010, 10:43 AM   #25
2005 19' Safari
GLENDALE , AZ
We had an old Chevy crewcab with a 454. Rebuilt the carburetor twice over the years, because the float went bad (sank) and overfilled the bowls, which flooded the engine. It would run, but no power. The big clue was a really strong gas smell from fuel running out of the carb. It's getting harder and harder to find anyplace that rebuilds carburetors anymore...
Old 03-13-2010, 10:59 AM   #26
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I have had the problem twice both times fuel filter.
What I do not understand is the loss of power in reverse but no problem going forward unless you got on it. Mine did the same thing.
Always carry a spare as they can go out with little notice.
Garry
Old 03-13-2010, 08:39 PM   #27
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Originally Posted by Buttercup View Post
no power to the MileMarker Overdrive.
was sputtering,
zero power
backfiring
wasn't enough power.
Had same, but at highway speed, second time on takeoff from light.
Turning key off and back on, it drove home, motor runs fine, proceeded to replace parts recommended by others and did tests, did a 2500 mile trip never to happen again, my problem is I don't know which item fixed it. So I hope you try motor after each procedure, then you will know what fixed yours as your problem isn't intermitant. Mine didn't have any symptoms outside of the two times losing power.
Old 03-14-2010, 01:28 PM   #28
Kmpro
kmpro's Avatar
Lubbock , Texas
Exclamation Sputtering cancels our trip
Just thought I would fire up my 454 and suddenly I had a BAD CASE of the Sputters. Could'nt figure it out for a minute, then hit the boost pump switch and viola! sputters gone. Seemed like ignition but when I hit the Auxillary pump everything went back to normal. The extra 3 feet added to the chassis when AS built it is more than the mechanical pump on the engine and the tank pump will handle on my rig, so the boost pump just back of the step has to be on or it's no go period.
Old 03-14-2010, 01:47 PM   #29
guy99's Avatar
Images: 16
I've never heard of a third pump. My 84 310 sure doesn't have one. Is your tank pump in the tank or external?
Old 03-14-2010, 07:55 PM   #30
Kmpro
kmpro's Avatar
Lubbock , Texas
I'll have to check the shop manual from Chevy, but I think the tank unit has a pump built in as part of it. Could be I'm thinking of the Ford chassis, so I'll check the manual. I do know I have auxillary pump amidship and the mechanical pump on the engine.
Old 03-15-2010, 06:28 AM   #31
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
Water in the gas tank. Add some 'Heat'. I had this problem with the Silver Bullet. One day I was putting gas in her and I noted gas running out on the ground. The fill hose had a hole in it. I replaced it that night in an RV park. Fixed that problem.
mel
choctawmel is offline   Reply With Quote
Old 03-15-2010, 01:18 PM   #32
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Well, I think we have found the problem(s). First the simple things, new plugs, wires, filters all the way around. In changing the plugs and wires (not an easy task actually, I discovered that the #3 cylinder wire was probably burnt up. When I removed the wire the internal connector stayed on the plug. When I yanked that off the plug and examined it I saw some carbon burnt stuff. I think the wire just failed.
The fuel filters were replaced. Did you know that on the 1990 345LE there are 3 of them? One by the gas tank on the suction side of the forwarding pump, one just forward of the stairs and the last on the carb body (for normally aspirated engines). I got 2 of the 3 changed. The one by the stairs was too hard to get out and not worth my time.
The cap and rotor looked clean enough to skip replacing.
Bottom line, it runs and we will head out this weekend for Death Valley. Sure hope I don't have to post from the road for help.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 03-15-2010, 01:27 PM   #33
"Cloudsplitter"
Thumbs up
KISS usually works...keep post'n
Good Luck...
Safe Streams..
Old 03-15-2010, 03:40 PM   #34
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Yahoo!! Glad to hear it was an easy fix for you. Don't regret the parts you replaced. They're all just part of routine maintanence. I went through that near Roswell, NM. It turned out I had bad gas somewhere. A bit of carb cleaner & topping off the tank twice with high test got me going. But only after a complete tuneup w/ new cap,rotor, & wires.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 03-16-2010, 12:58 PM   #35
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Such great news. To lose a road trip would be tragic.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Sureflow is wheezing and sputtering Sovereign42 Fresh Water Systems 2 10-28-2009 05:35 AM
Region 11 Cancels Annual Rally Alumaholic WBCCI Forum 24 10-06-2006 09:36 PM
Our First Trip Buttercup On The Road... 19 09-30-2005 09:05 AM
First Trip milesmason On The Road... 5 09-21-2005 07:53 AM
Sputtering water silvrtwinkie Plumbing - Systems & Fixtures 3 08-17-2005 06:53 PM
