Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 04-06-2003, 12:00 PM   #1
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
speedometer problems
well installed new speedo and new cable to xmission. the speedo works but it is shaking or viberating like crazy. i used white grease to lube the cable and i was told nota graphite is the only way. loaded the cable with graphite and the damping slowed quite a bit . but it is still doing the shake rattle and roll. added the cruise sensor and the movement increased. went back to the zone and they say give it some time it will go away.. any one kicked this beast ??? how did you clear the viberation???
lol
al
wb13798 is offline   Reply With Quote
Old 04-06-2003, 08:05 PM   #2
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 215
You sure it's not a Ford?
Had the same symptoms with an '82 Ford medium duty truck I owned since new.
The plastic drive gears in the trany sheared at 130,000 miles and 10 years.
Never personally been inside a Chevy transmission.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 04-06-2003, 08:58 PM   #3
wb13798
wb13798's Avatar
thnx
that is what im thinking , one gear is a piece of cake the other one is a pain. i have a trip to ohio i have to go on i think i will drive and see if it gets worse or stabilizes. plus i plan to talk to my buddy at mr good wrench tomorrow and get his thoughts. lol
al
Old 04-07-2003, 05:45 PM   #4
wb13798
wb13798's Avatar
mr no wrench relates stick a screw driver in the hole on the side of the xmission and see if it turns . if it turns you got bad gears if it doesnt probably not. he suggest i check the length of the chain the inside if the speedo cable to see if it might be too long since i bought the cable from auto zone. well i cut a inch off the bottom end and that improver the fluctiuations of the speedo . but at 65 to 85 mph it works as it should. ??? i dont know. some one mentioned a electronic speedo . if this doesnt clear i might go back and read the old mail. in alabam you got to have a speedo or you will be suppoting all the little towns with two cops and a jp. could get expensive.
al
Old 04-07-2003, 05:54 PM   #5
87MH
87MH's Avatar
Images: 215
Electronic speedo's
Electronic Speedometers are relatively cheap and inexpensive to install.
Check out vdo or whitney catalogs. Some aftermarket speed controls will output to an electronic readout utiliizing the speed sensing magnets.
Dennis
WBCCI # 1113
AirForums #1737
Old 04-07-2003, 06:12 PM   #6
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
The cruise control is sold under the Audivox name and should be available at an Autozone. They may have to special order it, and it should be in the $129.00 range. The box will have hoses, chain to connect to the throttle and a bunch of plates to make it work. The instructions are pretty good. I used the tach feed and mounted the provided magnets on the driveshaft.
The switches are mounted on the dash in a 1X1.5 inch blister that is illuminated at night.
On the speedo issue I will have to look in some of my bookmarks, but on Sunday on the way back From Mystic Springs Fred Hinds and I were running down I-10 and I was checking my speed against my GPS....................
There are lagre format ones available and then you would have navigation aids as well.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 04-07-2003, 07:44 PM   #7
thenewkid64
Just a member
Images: 21
I found it!
They are near daytona and make replacement gauges and custom rod gauges as well.
http://www.dolphingauges.com/progauges.htm
They have a line of mechanical gauges and a line of electronic ones too. I have not used them yet, but they are who I may go with when I tackle the dash job.
Brett G
Old 04-07-2003, 11:19 PM   #8
wb13798
wb13798's Avatar
how do you pull up the tech specs for the guages. also i will be in cincinatti this week another 75 miles and i could go to dayton and look these guy up . i have thrusday after noon free time . i put a lot of effort in the speedo and im ticked at what i have. maybe the graphite will work in and but the cruise has gone south now so im loking for something more reliable.. lol
al
Old 04-07-2003, 11:23 PM   #9
wb13798
wb13798's Avatar
duh i figured it out . geez
thnx al
Old 04-07-2003, 11:24 PM   #10
thenewkid64
Just a member
Images: 21
Al,
I did not give you all of info on the loaction of the company it is in Daytona, FL.
If you go to Dayton looking for it you will be dissapointed!
Brett G
Old 04-08-2003, 09:06 PM   #11
wb13798
wb13798's Avatar
o no . i called the company today and discussed the electronic package sounds simple to replace.
i also received a jc whitney today and it has a electronice speedofo a about half the price but not a lot of specifics . i hope the cable and chain burns in this weekend . auto zone assures me that is what it needs. time will tell. lol
thnx al
Clearcoat problems ipso_facto Clearcoat, Exterior Paint & Trim 11 04-01-2004 09:02 AM
Problems with viewing pics.. not loading?? Happycampers Forum How-To's & Support 8 02-26-2004 02:16 PM
Problems with Slide Outs? flyfisher Our Community 8 01-19-2004 02:10 PM
Length related problems: 29' vs 32' & 34' femuse Our Community 3 03-19-2003 11:17 AM
Speedometer Problems 1985air345 Mechanics Corner - Engines, Transmission & More... 1 05-13-2002 09:00 PM
