Old 10-09-2006, 09:33 AM   #1
silver buffalo's Avatar
Floyds Knobs , Indiana
Speedometer error
I have switched tires from the original (to me) Goodyear 8R19.5 to General 225/70R19.5. Looking at the Goodyear web site, it says there will only be a 2.25% difference in the spedo reading at 75mph. Well I have about a 10 mph
difference, the speedometer shows 75 and my actual speed is around 65. I don't know how accurate the speedo was before I changed tires.
I think the input for the speedometer is a gear in the transmission (?) and was wondering if anyone knew if all I had to do to correct it was to change the gear and also if anyone knows what the correct gear might be?
Rick Hill
83' 310
AIR # 2905
silver buffalo is offline   Reply With Quote
Old 10-09-2006, 10:20 AM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
I used to work on GM products and they do use a gear in the trans to adjust the speedo. Unfortunately it's been long enough that I don't remember the formula. It was something like one tooth per 2 MPH change either way. The gear is easy to change, should not be big $$ if it's done the same as GM. Not sure who makes your trans or if adjustments are the same. Your dealer should be able to help.
Fyrzowt is offline   Reply With Quote
Old 10-09-2006, 10:54 AM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The geears are different colors, you will need to pull your gear out so the parts person knows what you have, and give you a chance of getting the right one first time. If you can't get a gear that's close enough, you may have to go to a speedometer shop so they can make a reduction kit for you, the last one I had done cost about $100.
What Airstream Clubs do you belong to? airstreamcaravel Community Polls 44 09-13-2007 10:09 AM
I need a new speedometer for my '88 345 Mr. D Mechanics Corner - Engines, Transmission & More... 12 10-31-2006 03:39 PM
Store your photos @ AirstreamPhotos.com! Andy R Forum Admin, News and Member Account Info 63 09-06-2004 10:02 PM
speedometer problems wb13798 Mechanics Corner - Engines, Transmission & More... 10 04-08-2003 08:06 PM
Speedometer Problems ViewRVs Mechanics Corner - Engines, Transmission & More... 1 05-13-2002 08:00 PM
