Old 03-29-2008, 11:03 AM   #1
Speedometer cable
The speedometer needle in our 1984 310 is starting to bounce some. Before it gets to bad I'd like to solve the problem. In the old days you used to use graphite to lube the cable with. Is that still the recommended method?
My plan is to undo the cable from the speedometer and the transmission and then pull the inner cable out. I'm guessing I have to pull it from within the cab. Once I have it out I'll clean the cable and rub graphite on it then reinsert it into the tube.
Does this sound like a reasonable plan? My only real concern is when pulling it out its going to be tough not to get grease on everything inside the motorhome . I don't think Susan would like that at all .
Thanks!
Old 03-29-2008, 01:30 PM   #2
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I cannot tell you what is the correct thing to do, but I can tell you what I did to the cable in my first Toyota pickup. It started to "bounce" at about 125,000 miles. I took it loose from the speedometer and while keeping that end high and pointing up I added a few drops of 30 wt oil. I did this two or three times a day for several days and then reconnected the cable. This "fix" caused no problems and gave me another 50 to 60 thousand miles before it needed replacement.
There are probably better things to do, but I just did the easiest thing I could think of by using what I had on hand.
If you find the perfect fix (short of replacement) let us all know.
Sam
samb is offline   Reply With Quote
Old 03-29-2008, 01:50 PM   #3
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Yep, I had to do that too. On mine the sender to the cruise control went bad and was causing some problems as well. Graphite the cable.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 03-29-2008, 04:15 PM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Graphiting the cable is still the best fix.
Inner cables will have an end that will not slide through the housing, if you luck out, it will be the end outside the passenger compartment, and you can slide it out and reinstall it without a mess inside.
Old 03-29-2008, 04:35 PM   #5
Thanks for the suggestions. I hadn't considered that the cable didn't go straight from the speedo to the transmission. Where is the cruise control box located? Unfortunately I'm not in a position where I can walk out and look at the motorhome right now so I'm just trying to picture in my mind how its routed.
Thanks!
Old 03-29-2008, 04:54 PM   #6
Well Preserved
1993 21' Sovereign
Thanks!
Usually the cruise transducer (the old-timey, "technical" name) is located on the left inner fenderwell area. Follow the speedometer cable up from the tailshaft of the transmission, eventually you'll run into it.
Old 03-29-2008, 05:00 PM   #7
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Many of the speedo cables pull out of the housing from the tranny end. That would keep the mess to a minimum and make lubing it easy.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 03-30-2008, 08:39 AM   #8
I hope this is the case. As long as these are it would be like wrestling a slippery snake!
Old 03-30-2008, 09:04 AM   #9
The Hawk's Lair
cooperhawk's Avatar
Well, on mine the speed control transducer is mounted on the left side of the transmission and the cable end fits into it. You can tell because two wires run from it. Also, my cable came out of the casing behind the dash. You have to disconnect it from the speedometer and then pull it out. Lots of fun.
Either disconnect the batteries, or take off you watch and rings before you reach behind there. Lots of voltage!
AKA THE GUNNER
VFW, LEGION, NRA
Old 03-30-2008, 09:14 AM   #10
Thanks for the reminder on the batteries. I might have remembered about the time sparks started flying, its always nice to not have to go through that however!
I'll check out the speedo cable routing when I get home next week.
Thanks!
I need a new speedometer for my '88 345 Mr. D Mechanics Corner - Engines, Transmission & More... 12 10-31-2006 03:39 PM
Speedometer error silver buffalo Mechanics Corner - Engines, Transmission & More... 2 10-09-2006 10:54 AM
Dead Speedometer Alice Airstream Motorhome Forums 8 03-06-2004 07:58 PM
Speedometer recommendations wb13798 Mechanics Corner - Engines, Transmission & More... 15 01-01-2004 08:18 AM
Speedometer Problems ViewRVs Mechanics Corner - Engines, Transmission & More... 1 05-13-2002 08:00 PM
