Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 11-14-2002, 08:57 PM   #15
rdm
rdm's Avatar
Profile:
Unhappy Update
Well everyone we hope to leave for South Carolina on saturday by noon.
Our manifolds had zero cracks and zero broken studs therefore we remounted the right hand side.
The heat riser diaphram was shot so we wired the butterfly open and blocked the vaccum line.
We replaced the alternator with a rebuilt it work for 20 miles -while I drove to a friends shop to rebuild the carb ( maybe next year we will put on the Edelbrock) but when I arrived we tested it and it was a dud ,the local auto parts store will replace and has offered to pay for installation I hope we can replace the alternator faster this time.
Evelyn and I are looking forward to our trip and would like to thank everyone for helping us.
I am one of the members that stays in the background reading and learning. I hope to meet some of you next spring at Mystic Springs.
Ray & Evelyn
rdm is offline   Reply With Quote
Old 11-14-2002, 09:05 PM   #16
PeterH-79MH's Avatar
Profile:
Images: 63
Ray,
Have a good trip and be safe!
Post us a note, if you get a chance.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 11-15-2002, 09:30 PM   #17
rdm
rdm's Avatar
Profile:
Exclamation Help !!!
We picked up the motorhome this evening. The second alternator was installed this afternoon. The coach battery tested poor under a load test I left this battery in on the way home and was going to replace it on saturday before we leave (We Hope). On the way home the volt meter strarted surging from 11 to 13 the headlights would dim.
Is there something wrong other than the alternator or is it because of the poor battery.
The forum's help would be appreciated
thanks Ray
Old 11-15-2002, 09:37 PM   #18
Silver Bullet's Avatar
Profile:
If you have a Ford set-up, it's the "voltage regulator". These should be replaced when new alternators are installed. Oscar
Silver Bullet is offline   Reply With Quote
Old 11-15-2002, 09:42 PM   #19
rdm
rdm's Avatar
Profile:
The coach is a gmc p30 the alternator was replaced with a unit with a built in regulator. The old Lestek regulator was removed.
Thanks Ray
Old 11-15-2002, 09:57 PM   #20
Profile:
Hate to say this , But....
If your battery was low and/or tested low under load, you cooked your new alternator. Instuctions on any new alternator state that battery should be fully charged. Wish I didn't have to tell you that but, trust me, I've done it before too! (once) Oscar
Old 11-15-2002, 10:19 PM   #21
Profile:
Images: 63
Oscar,
Can you elaborate on the low battery/alternator situation. I want to understand the reason for a new alternator to fail under those conditions. One thing to keep in mind is the fact that 2 more batteries (the coach ones) are also present in the charge system via the battery isolator.
I have replaced many alternators, but never have encountered that problem.
thanx
Old 11-15-2002, 11:09 PM   #22
Profile:
Sure Peter....
What happens is the "new" alternator is maxed out charging a weak or dead cell or (semi-dead cell ) battery. Coach batteries won't have anything to do with fluctuating head lights. All the isolator does is seperate the charge, so the "vehicle" and "coach " batteries don't drain from one another. If the coach battery was low also that would put twice the strain on the alternator.
When your headlights are on and the motor is running, the lights get their juice from the alternator, when motor is off the battery does the work, but if the battery is low and the lights are on, it's powering lights, vehicle battery, coach battery, etc.
As to why you should "break -in" a new alternator by not putting full loads on it, I'm not sure, but (as I said before) I have proved the manufacturer right on this one. Oscar
Old 11-15-2002, 11:16 PM   #23
rdm
rdm's Avatar
Profile:
Peter
Can there be something else wrong with the charging system.
Threr is an audible snap noise when the volts drop off as the unit is idling I traced this noise to the front area near the isolator to a Bosch 30 module with 23 wires coming off it this appears to be a solinoid of some type it is located after the 3 wiring blocks connected to the isolator.
Any ideas
thanks
Ray
Old 11-15-2002, 11:23 PM   #24
rdm
rdm's Avatar
Profile:
Oscar
The battery was testing 11 to 12 volts. The person that did the load test said it was drifting low and reccomended changing the battery. most of the drive home the voltmeter read 13 only when this snap sound was heard did the reading drop to 12.
I discovered this when I got home.
thanks
Ray
Old 11-15-2002, 11:27 PM   #25
Profile:
Two questions....
Was the volt test done with motor running and is the alternator the same AMP rating as was taken off? Oscar
Old 11-16-2002, 07:55 AM   #26
Profile:  LOST , Hawaii
Replace the battery. If you have 13v running and 11-12v off the battery the alternator is still putting out power. The battery might not be good but it started a BB Chevy so it can't be all that dead and shouldn't cook an alternator.
Didn't you go from a 60 to 100 amp alternator? That is pretty good sized for a single battery starting system. I would look at the Bosch solenoid. If it has 23 wires it feeds a bunch of circuits and it would not be suprising to see a voltage drop on a marginal battery. I would want to know why it is kicking in and out for future reference.
John
74Argosy24MH is offline   Reply With Quote
Old 11-16-2002, 01:54 PM   #27
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
Man all the electrical issues can make you nuts quickly.
I wantd to mention again what happened to ours over the summer trip...a somewhat burnt wire from the module to the starter caused what seemed to be an alternator/battery isolator fry. I did replace both, but later found the problem to be the wire which was making intermittent contact with the starter solenoid terminal.
Victim of heat from the manifold. Probably didn't need the alternator or isolator, but thankfully neither was more than 40 bucks.
Old 11-17-2002, 10:11 PM   #28
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Oscar,
I too have heard that a low battery or one with one or more bad cells can cause enough strain on an alternator to make it go bad. For the record, my wife's '95 Astrovan with 4.3 V6 runs a 105 amp Delco alternator as does my '01 Chevy 2500hd. Both use one battery.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
The exhaust manifolds are off! Now what? swebster Mechanics Corner - Engines, Transmission & More... 13 08-07-2005 01:29 PM
Exhaust ALANSD Airstream Motorhome Forums 44 11-30-2003 10:23 AM
Right cast iron manifold free Astrodokk Airstream Motorhome Forums 1 10-19-2003 10:04 PM
Exhaust pipes to exit left but where? Astrodokk Airstream Motorhome Forums 6 10-18-2003 09:21 AM
Furnace Exhaust niftypkg Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-27-2002 10:19 AM
