Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 11-04-2006, 04:53 PM   #1
ralley
Profile:  Prince Frederick , Maryland
Talking Slow battery drain solved
For some while--since before I bought the AS MH last year--I have had a slow drain of the starting battery, causing it to go flat in about 30 days. Replaced the battery which came with the MH. The repalcement went flat in 30 days. Pulled all the ground connections I could find and cleaned them up with a dremel tool. Battery went flat in 30 days. Disconnected the battery ground. Battery went flat in 30 days. Hmmmmm.
I then figured that it was possible that the battery bank combiner solenoid was faulty, so looked to see if I could pull it off the truck and test it. In the process, I sorted out the problem--we are now at 45 days without a flat battery.
Either the PO (or the factory in 1991) routed the positive cable from the generator across the top of the solenoid. It is attached to the LH solenoid post. It had sagged so that it vibrated against the RH post until the cable insulation had worn off, causing it to short out across the two posts and a have a slow, (as in imperceptible) drain. It took a strong light to find the break in the cable insulation.
Re-routed the cable, and taped up the insulation.
Best to all,
R.
ralley is offline   Reply With Quote
Old 11-04-2006, 08:32 PM   #2
noiva
noiva's Avatar
Profile:  Chesapeake , Virginia
Images: 46
Great detective work, Rob! I had a somewhat similar thing with the Blimp. Turned out the last "repair" shop that had worked on the coach for the PO had touched the wires together from the starting solenoid and the house solenoid, thus causing all batteries to be connected all the time. Pure accident I found it out, just about like your situation. I'd let it sit for 30 days without a shore line (unusual for me), and no power to start. Pulled the switch in the glove box to use the house batteries, and nothing changed. Still no start. Took an auto electric shop to figure out what was going on ($ ), but they did fix the problem.
Hang on, something else will go wrong soon enough.
Best,
Tim
No More MoHo
1989 34X
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Battery Location uwe 1970-76 Tradewind 22 09-04-2003 08:44 PM
low drain points Raptorrider2001 1999 Safari 18 12-12-2002 05:17 PM
Second Battery w9det 1999 Safari 5 12-06-2002 07:42 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 02:03 PM
