Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 03-08-2003, 07:23 PM   #1
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 215
Shock Replacement Time?
Hey guys, I have a question on shocks specific to Motorhomes.
I tried to locate a recent thread on shocks, but the only ones I found were about a year old.
I have been unable to locate the replacement of any of the shocks in the maintenance history of the 1987 345, so at 16 years and 72,000 miles I suspect that it is about time.
I can set up a rocking (rolling) cycle by utilizing the entranceway step, two or three load cycles establishes a movement of about one half inch measured at the step bottom. The roll cycle will then continue for about four more cycles before no movement is discernable.
Two questions:
1 –
Is this continued rolling movement (4 cycles) serious enough to indicate worn shocks, and,
2 –
After I have the first shock off, what would an “unacceptable for further duty” test be?
I know the amount of work and time I am looking at, it would make no sense at all to go back on with an old shock, but I was just wondering if there is a rule of thumb for a P-30 type of shock that would indicate excessive wear, say 1” of immediate movement with a 100 pound force applied?
Anyone have any sources for (or thoughts on) a good Bilstein shock for the rear (tag axel) suspension, or an experienced based suggestion for the front spring assisted shocks?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 03-08-2003, 08:07 PM   #2
want310
want310's Avatar
Profile:
Thumbs up shocks
Dennis
I don't know the formular for shock changes but if you go the Bilstien route here is where I got mine. This outfit is thumbs up as far as price & service. I recently installed them on my MH (not an A/S).
http://www.shocksonline.com/bilstein...ocks.asp?make='FORD'&model='E350,%20E450'&year='1998'
The page will open to my MH specs. I'm sure you can navagate the site to the P30 specs.
Steve
Another link.....front end assist etc.
http://www.timbren.com/
want310 is offline   Reply With Quote
Old 03-08-2003, 08:12 PM   #3
want310
want310's Avatar
Profile:
Thumbs up shocks
Dennis
Steve
Old 03-09-2003, 09:41 AM   #4
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Hey,
If you are going with Bilstiens, I can can tell you that I found a place on the web, I got 4 for dirt cheap.
shox.com
I in no way represent this company, I just heard of it from the car club forums. You will be shocked- no pun intended, on how cheaply they sell the Bilsteins for....
Regards,
Eric
replacement 66-67-68 window glass available rluhr Parts Archive 23 08-06-2004 02:05 PM
Shock absorbers changing gary 1970-76 Tradewind 8 03-10-2004 07:15 PM
Attention: Driveway Campers _ time to hit the road ! femuse Our Community 5 04-04-2003 01:01 AM
Shock time Dbraw Shocks 5 03-08-2003 05:04 PM
63 TW shock Moonshot Shocks 5 08-26-2002 10:24 AM
