Old 06-19-2012, 12:01 PM   #1
kmamedia's Avatar
2002 26' Land Yacht 26
Seabrook , Texas
Angry Service Engine Soon
My 2002 Landyacht, 8.1 Fortec, my service engine soon light comes on randomly, had OBD2 checked, no errors shown. Any hints are appreciated.
kmamedia is offline   Reply With Quote
Old 06-19-2012, 12:43 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Programmed service interval
I know some manufacturers have this built in to their software.
In the days I had vehicles by a British manufacturer, the OBD software triggered a "Service engine" light every 52,500 miles. It went on like clockwork.
There was a little "black box" under the dash where 2 pins were shorted to reset the light.
Perhaps this is the case here? I believe there is a profound difference between service engine and check engine.
Good luck!
Old 06-19-2012, 01:16 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Did you have the scan done with a generic code reader or the GM scan tool?
Generely speaking the DIY type readers only display faults when there is a hard fault present.
Better commercial scanners will read sporadic faults but early OBD systems often won't display freeze frame data on a sporadic code.
The dealer specific and high end pro versions will read just about everything.
If you only have access to a DIY tool carry it with you and scan for the codes when the MIL is on.
Good luck,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 07-10-2012, 06:58 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
On our Tacoma, we get a service engine light warming that flashes when we are 500 miles from a scheduled maintenance...if eventually turns solid and remains lit until we have the service done and it's reset. Look at your owner's manual to determine what the light means...or have the code read at a Checker or other auto store.
TB & Greg and Abbey Schnauzer
#3954
Old 07-10-2012, 07:11 PM   #5
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Good luck,
Tom.
What Tom said!
OBD2 is a nice idea but not exactly the end-all. There are lots of systems in a modern vehicle that can impact that check engine light (MIL). Not all show up in OBD2. Find a mechanic with a real scan tool and the knowledge to use it.....
Bruce
Bruce B is offline   Reply With Quote
Old 08-04-2012, 02:52 PM   #6
kmamedia's Avatar
Seabrook , Texas
Well finally got my problem solved.
First, fuel filter was badly pluged, its a pitch to put it in, muffler sit right in fron of the inside rail.
Second, spark plugs, they where real bad burned (Denso Plugs) 45,000 miles.
Now its passing all the Big Rigs on the road again
