Fred,
I am always keeping my eye on AC prices as my 1976 Armstrong (the original), one day is gonna quit and then I will have to decide, Fix or replace?
When we replaced the Armstrong on our 77 Airstream TT we went with a Coleman beacuse we could get a 15000 BTU model. It worked well but was LOUD.
The new carrier units are aggressively priced; I have seen them at 499.99 for the 13500 BTU with the inner and outer shroud. They have some special kind of system that spays the condensate water (the stuff that runs down the outside of the MH) on the coils to help make them more efficient. The Colemans are good, but in the 660.00 range and the duo therms list close to 800.00.
Lower amperage makes sense, but with your Generator it really shouldn't matter.
Almost all RV places will recommend replacement vs. repair as the install time on a new unit is usually less than the diagnostic time on a old one. To DIY you will need an extension ladder, some plywood a few carpet scraps, rope and some help with a good back.
Pull the inner shrouds, and disconnect power and remove all fasteners that hold the system to the skin on the inside.
Place the extension ladder against the side of the coach on top of the main awning. The awning roller will distribute the weight as you climb the ladder. Place carpet scraps soft side down on the skin between the AC unit and the ladder, place plywood over the carpet. The carpet stops scratches and the plywood distributes weight. Use a wide enough piece of plywood that you span 3 or more ribs. Remove outer shrouds, remove any additional fasteners, disconnect any wiring, and pull the unit off of the roof.
After placing the unit on the plywood, tie the rope around it.
This is where the help with a good back comes in. You will be on the roof with a 100+ pound AC unit that you DO NOT want to drop. Things dropped off the top of the MH tend to bounce. Bouncing alongside the MH tends to make nasty non-removeable marks. Give the gift of old AC to your helper while you hold on to the rope. Let the old unit slide down the ladder. Once you pull it out there is no reason to be gentle with it we just want to avoid the bounce.
New install instructions will be provided with whatever brand you buy. Remember where they are so you can refer to them later.
Here is a link I have to a place that ships the Carrier for free.
http://www.rvsupplywarehouse.com/car...nditioner.html
The only drawback to the carrier is that they could bail out of the RV market and leave you stuck with a unit that is hard to get parts for. But they have been around forever, and this is a unit they build not a re-branding of someone else’s unit. Just a little food for thought.
