Old 10-07-2015, 11:32 PM   #1
bigbidule's Avatar
1981 28' Airstream 280
Lisle sur Tarn , France
Remove cruise control
hello. On my excella 1980, I don't have the engine control module of cruise control. I would like to remove all wires and small hoses : is it possible without problem ? My engine is a little bit shambolic !!! Thank you. Marc
bigbidule is offline   Reply With Quote
Old 10-08-2015, 07:07 AM   #2
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Marc,
I would leave everything in its original place and function. You can easily disconnect the cruise control feature by removing the Cruise throttle cable. The powertrain works as a system. Some components can be disabled without causing a problem. Others cant.
NavyCorpsman is offline   Reply With Quote
Old 10-08-2015, 08:17 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Just remove the cruse control cable that is connected to the throttle arm. If you start removing vacuum hoses you may effect the transmission shifting.
2004 Excursion 4x4
Old 10-08-2015, 09:47 AM   #4
bigbidule's Avatar
What 's that ? (black cylinder with a lot of wires and a hose (free and not connected!)
ID:	250021   Click image for larger version
Old 10-08-2015, 09:51 AM   #5
bigbidule's Avatar
if I could remove this "cylinder" there will be not wire anymore ( !!! my english )
Old 10-10-2015, 12:54 PM   #6
bigbidule's Avatar
All is now removed and excella is still runing....good news. hahahaha
Tomorrow I swap the diode isolator with a relay Cyrix ( I am waiting for a new 140A alternator from Summit racing )
Throttle tension & Cruise control Chaplain Kent Mechanics Corner - Engines, Transmission & More... 10 07-14-2005 09:01 PM
Cruise Control Chaplain Kent Mechanics Corner - Engines, Transmission & More... 4 10-14-2004 07:56 PM
1984 motorhome cruise control cooperhawk Airstream Motorhome Forums 2 12-25-2003 08:12 AM
No cruise control on '92 30' fangthorpe Mechanics Corner - Engines, Transmission & More... 3 05-09-2003 09:46 PM
Cruise Control Servo Diaphram zamboni Airstream Motorhome Forums 5 06-26-2002 09:14 PM
