Old 03-23-2019, 08:44 PM   #1
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
Rebuild suspension
Was ready for a tighter drive after almost 100k on the old stuff.
Super Stear springs and bell cranks.
All new ball joints, tie rods, bell crank arms, sway bar bushings, and new Timken wheel bearings.
Also installed new Bilstein shock all around and steering dampener.
New polyurethane sway bar bushings on the rear.
While I was at it, decided to help the braking with new Stop Tech rotors!
With the new springs, no more air bag needed and back up to proper ride height, and no longer a low rider!!
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (265,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 03-24-2019, 02:39 PM   #2
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey
Looks good, love the blue paint. .25 camber. 4.5 -5.50 degrees in caster, and .08 in inches for total toe. Get a total 4 wheel thrust angle alignment. The configuration of our coaches on a hunter alignment machine, will come up as a tandem axle non alignable rear axle. There is very little we can do with our coaches rear axle wise. But it is nice to know where the axles sit in relation to the front axle readings. If I'm available this summer, I invite you to come up here, and I'll align it for you. I may be gone for a job, but if available I offer that to you. DJ
davejay is offline   Reply With Quote
Old 03-24-2019, 03:57 PM   #3
mayco's Avatar
champaign , Illinois
Welllllllllllll, how does it feel? Was it worth it? I'm almost there, done tie rods, ball joints, bell cranks, air bags, shocks, sway bar bushings, fresh alignment...I think my next job will be the steering gear box at some point. It handles sooooooo much better now.
mayco is offline   Reply With Quote
Old 03-24-2019, 05:24 PM   #4
Hey,
The cool thing about driving big things, is that you can really feel the difference when something gets replaced. On a car, not so much. Our coaches are big ,top heavy, and long. So everything road wise is working against us. Those new parts will really come in handy driving western roads that are rutty.our front wheels are narrower than the back end,thus the tendency to have to steer it all the time. Your either in the rut or trying to straddle it. My 2 GMCs were really bad for that. Being front wheel drive made it worse. AS are at least rear wheel drive, with duals so that makes it a whole lot better.
On a differant note. When you guys get ready for an alignment, go to your nearest tire shop, ask for the name of their Hunter service rep. If anyone can tell you what's a good shop, or where to go for a good trustworthy alignment, it lol be him he probably trained the guy who will do your coach. And being a 310, it's no differant than doing a one ton daully. Just longer. No tag axle.
If they opt out of doing a 4 wheel thrust angle alignment, just have them do a 2wheel front end alignment. The worst that can happen is a cocked steering wheel.( very likely) they can fix that, but you can too. Remove your steering wheel from it 9 bolt adapter ring, and turn the wheel until it's straight. Probably one bolt hole will do. This will not affect the steering at all, or the centering of the steering gear. You may ask the tech to give you a .25 degree more caster on the right side. That will give the coach an inclination to pull left. Great for crowned roads. You'll hardly notice it on a flat road. It may drift a tad left if you find yourself in the left lane. I also think your to far from me for me to align it . Local may be a better option for you guys. Good luck. DJ
Old 03-24-2019, 06:37 PM   #5
cmadmaxman's Avatar
Images: 37
I used the recommended settings supplied by Super Steer. The tech did a great job, but did not like the camber on the right side. Took it back out I think to keep from pulling a little right. He drove it twice or more to make sure it all was tracking like it should. I will be taking it in after our trip down south next week to see how everything settles in. I had a clearance of 3/4" from bump stop to now 2 1/2".
The weight of the front (by our local COOP) was 4800 lbs.. So I got the 5000 to 5300 lbs. springs.
When I took it out after he got done with it, there was about a 15+ wind, and it did buffet a little, but nothing like it was. We have some bridges with bad approaches on them here locally and before would bottom out the front suspension, but not even close now!!
I just tightened up the steering box, but did not tear into that.
Problem I have now is the rear springs, or whats left of them after they were cut off for the air bag system. There should be 10" from the frame to the air bag bottom bar. I have 9" and that is after I raised the air valve a little. Of the 3 holes in the system, I'm on the bottom hole, so the back of the springs ride on the frame when all the air is out of the bags!
Have found new springs for around $750 a pair, but only rated for 9k. I'm going to ck with a spring shop in Nashville to see what they might be able to do.
Thanks for the offer Dave, but our trip this summer will not be taking us your way, maybe next year when we retire!!??
AIR Member 12654
1982 310 MoHo
Old 03-24-2019, 07:28 PM   #6
cmadmaxman's Avatar
Images: 37
My Bad, the front weight with me in the coach, was 4980 lbs.!
AIR Member 12654
1982 310 MoHo
Old 03-24-2019, 08:01 PM   #7
mayco's Avatar
Awful nice of you to offer your help DJ! Good on ya
Mike
(I also used the spec supplied by Suprsteer after the bell crank install)
Old 03-24-2019, 08:27 PM   #8
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
When there is no air in the bags the back of the springs do ride on the frame because there is nothing else to stop them. This is why is it so important not to drive with no air in the bags. If you go back to your leveling valve there is a nut on the valve arm a couple of inches from the pivot point. Loosen that nut and there is quite a bit of adjustment in the arm itself.
The leaf springs don't do much as far as carrying the load because of the air bags. If you want to tighten things up replace the bushings at the front leaf spring mounts and also the bushings on the dog bone link between the air bags.
Cheers, Dan
~ Margaret Thatcher ~
Old 03-24-2019, 08:42 PM   #9
cmadmaxman's Avatar
Images: 37
That's what I was thinking Dan, but over the years, the springs now are arched up! When these units came from Airstream with the air bag carrier system they were in the center hole. At least that is what my manual says!?
Your right about don't drive it with out air in the bags. They say if you lose air, only 45 mph max! There is hard stops in the proper air bags so keep it from dropping to low.
Looking into it anyway. Would like to do it, if I have to, when I drop the rear end for a rebuild.
AIR Member 12654
1982 310 MoHo
Old 03-25-2019, 07:33 AM   #10
Magnet18's Avatar
Churubusco , Indiana
Very nice!
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 03-25-2019, 01:59 PM   #11
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
http://www.oemys-performance.com/med...-alignment.pdf
'Along the way, you have probably encountered your share of not-so-competent mechanics and/or alignment shops. Matter of fact, many alignment shops simply don't know how to deal with this motorhome version of the P Chassis and wind up treating it like a truck.
We will show you that simply telling the alignment shop that it's a “P30 Chassis” will almost guarantee you an incorrect alignment. Your Class A motorhome is NOT built on a “P30 Chassis”. The correct general term is a “Motorhome P Chassis”. The P Chassis was also used for what is referred to as a Commercial (Forward Control) truck. The same chassis series has been used for G10, G20, G30, P20, P30, and Motorhomes under a '32 - 52' designation. What's more, the alignment specs are different for the motorhome chassis because they were made slightly different.'
Boom Sounds is offline   Reply With Quote
Old 03-26-2019, 07:22 PM   #12
Hey,
You are right about the MH being different than a p 30 chassis. They are very close though. The steering assembly is differant,steering gear is more like a step van, they stretched the frame. So it is possible you have differant Ackerman arms on the spindles. Other than that it's pretty much a p30 set up. With our lengths , the caster specs may be differant. If your coach rides almost level, then frame angle is unimportant. You probably wouldn't t notice any change anyway. That's one of those engineer things.
I'm curious, what was the bell rank specs. Did they run negative camber on the right side? That's the road crown thing.. I prefer equal camber, and a little caster offset.
Glad to help may see you on our way to Alabama for thanksgiving.
So far as rear springs are concerned? My coach has 5500 miles on it, and the rear springs are pretty flat. The airbags are the springs. The springs are only holding the axle in place. And p30 chassis didn't have a lot of arch to the springs in the first place. The overloads that were above the main spring pack did the heavy lifting. We don't have that extra spring pack, the bags do that function. Alright, see ya. DJ
Old 03-26-2019, 07:34 PM   #13
Hey,
Your right about taking it back in a couple of hundred miles those front springs will settle a little. Your camber will go up a little. From, say .25 to maybe .50 . Not to bad but enough to notice a difference in steering, it may get a little lite feeling. You want to ride on the tire not on the edges.
Boom, your right about alignment techs. I trained at least 300 guys. I wouldn't have trusted my cars to more than 10 of those guys. Take it to an alignment shop. It's what they do, truck shops are the best, they do it all day, and there techs specialize in big truck alignments, and they know stuff like toe out in turns, frame angle vs caster adjustments, axle set back all the stuff you never really have to be concerned about with. Car.
I painted my anti sway bars red. Cause that makes the AS faster... DJ
Old 03-26-2019, 11:19 PM   #14
cmadmaxman's Avatar
Images: 37
rear springs
On the right spring, some PO has put in a 5/8" shim to try to bring it up level with the left side. There is a negative arch on the right side and level on the left with no water in the tank. Here is some shots of both sides.
Right side, notice the spacer block under the spring pack.
Left side, no water in tank.
I wanted to take it to a truck shop here in town, but the owner passed away and the family did not want to keep it going, and they did great work!
I'll take a shot of what Supersteer suggestions for alignment.
AIR Member 12654
1982 310 MoHo
Independent Suspension on an Airstream - Timbren Axle-Less Suspension BoldAdventure Axles 23 04-02-2017 02:45 PM
How would you rebuild the motor if you had to? Impala SS Guy Airstream Motorhome Forums 8 01-18-2008 07:56 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 01:01 PM
