Old 04-07-2019, 05:02 PM   #29
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey,
I remember reading your post on the dogbone bushings. I so wished I had done that when I had the gas tank out... It's got 80 gallons in it now. So I got to squeeze this 6'8" 290 pd frame in there. I wish I was 30 again. Piece of cake. Well you got everything covered on the rear end it appears.
Question, how do you get the axles out. I'd like to replace the wheel seals, and maybe the pinion seal. Can't figure out how they come out. DJ
davejay is offline   Reply With Quote
Old 04-08-2019, 08:26 AM   #30
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
I worked on a 2000 chevy dump truck a while back that I think was an Dana 80, but about the same hub assembly. I took some photos of the axle and rear hub assembly. You will need the special socket to remove and re-install the retainer nuts. I have the photo attached.
The pinion seal, I replaced on the MO, and to install it with out leaking, had to make a install tool to get it in right without leaking. I will get a photo if the tool I made to do that.
We have a full floating 70HD Dana. The ratio on my MO is 4:56. More on that to follow.
Here is some photos:
Hope this helps DJ.
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (265,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 04-08-2019, 05:38 PM   #31
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Excellent pictures ! Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 04-09-2019, 06:23 AM   #32
Hey,
Thanks for the pics. So I take it, the axle slides out of those splines? Do you need a puller, or does it just slide out. I got the socket for the nut underneath the axle. I looked at this setup when we first got the MH. Doesn't look like a hard job at all. Nothing is leaking,just thinking about doing it. DJ
Old 04-11-2019, 12:02 AM   #33
cmadmaxman's Avatar
Images: 37
They should just pull out. Incase they don't, The end has a taped hole for a puller. Not sure but think 1/2-20?
AIR Member 12654
1982 310 MoHo
Old 04-13-2019, 08:10 PM   #34
cmadmaxman's Avatar
Images: 37
Out with the old springs
Well, got the tail end up in the air and have the rear end and springs removed.
All new springs, bearings, seals, brakes and rotors, not to mention many hours with the bead blast booth!
Here is the pinion seal install tool that I made. These seals are a bear to install without pushing on the inside lip to install, especially with the pinion installed!
ID:	338088   Click image for larger version
AIR Member 12654
1982 310 MoHo
Old 04-14-2019, 02:06 PM   #35
Hey,
Now that's the way to yank a rear end out. You going to paint it too? Gloss black...I hate putting stuff back together dirty. Aren t those adjusted springs the cheesiest thing you ever saw. Just take out the torch, and knock off the ends. Didn't t even take grinder and clean up the edges. How much did these things sell for? Do your new springs have that thin nylon spacer in between the springs? Well, it ought to ride a little better. That weak leaf side would tend to hog down on a bump, making for a weird twisting feel. I wonder if you got a couple of broken leafs at the center bolt hole. I'd be curious as to why it needed a shim only on one side. Maybe parked on a hill for a long time. Anyway, cool. Would you post a pic when it's all ready to go back in? DJ
Old 04-20-2019, 09:14 PM   #36
cmadmaxman's Avatar
Images: 37
Going back together
Starting to put things back together after lots of cleaning. Also you can see the new springs that I'm putting back in.
Found this when I took the carrier out of the housing. 98,000 miles and the one spacer shim almost gone, and others with signs of much wear on the same side!
AIR Member 12654
1982 310 MoHo
Old 05-06-2019, 08:18 PM   #37
cmadmaxman's Avatar
Images: 37
Attachment 338678
Attachment 338679
Attachment 338680
Attachment 338681
Attachment 338683
Attachment 338684
Attachment 338682
Son's coming over in the morning, and going to hopefully have it sitting on all rubber before the days over! Everything cleaned and painted, even the wheel wells Click image for larger version
ID:	339944Click image for larger version
ID:	339945Click image for larger version
AIR Member 12654
1982 310 MoHo
Old 05-10-2019, 06:39 PM   #38
cmadmaxman's Avatar
Images: 37
Well it's back on the ground. First test drive went good. A little higher on the tail, about an inch to 1 1/2.Click image for larger version
ID:	340341Click image for larger version
ID:	340342Click image for larger version
ID:	340343Click image for larger version
AIR Member 12654
1982 310 MoHo
Old 05-10-2019, 06:42 PM   #39
cmadmaxman's Avatar
Images: 37
What am I doing wrong with the photos? It's posting 2 instead of one!?
AIR Member 12654
1982 310 MoHo
Old 05-10-2019, 06:49 PM   #40
cmadmaxman's Avatar
Images: 37
O well! Must show double until you refresh! Now only see one each
AIR Member 12654
1982 310 MoHo
Old 05-10-2019, 07:05 PM   #41
mayco's Avatar
champaign , Illinois
Beautiful work!
mayco is offline   Reply With Quote
Old 05-10-2019, 07:23 PM   #42
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
Rebuild suspension
Re photos: I noticed that sometimes when I initially post, 2 copies of a photo show up in the app, but eventually when I refresh the thread Iím view it corrects itself. I only see 1 of each photo in your posts.
Btw, I follow all the Airstream Motorhome build threads just bcs Iím so impressed what all of you are able to do IN ADDITION to all the other tasks that come along with renovating /maintaining an older Airstream.
Nice work!
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Independent Suspension on an Airstream - Timbren Axle-Less Suspension BoldAdventure Axles 23 04-02-2017 02:45 PM
How would you rebuild the motor if you had to? Impala SS Guy Airstream Motorhome Forums 8 01-18-2008 07:56 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 01:01 PM
