Old 12-05-2005, 01:31 PM   #1
1979 28' Argosy 28
Cullman , Alabama
Rear Stabilizer Bar P-30
I was wondering if any one has had any problems with their rear stabilizer bar. I have a 1977 p-30 Argosy and have replaced the bushing and the bar does not extend the full length through the bushing. I don’t know if this is normal due to the fact that when I bought the RV the right rear air bag was bunched up and the stabilizer bar was out of the front brackets and tied up to the frame with rope. Could anyone tell me how to fix this? The bar only extends about half way through the bushing.
Stantank is offline   Reply With Quote
Old 12-05-2005, 06:37 PM   #2
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Wow, sounds like something basd happened to your undercarriage. Did the PO give any explination for what happened?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 12-05-2005, 10:16 PM   #3
1979 28' Argosy 28
Cullman , Alabama
I’m still trying to find out what exactly happened to cause this. Would anyone happen to have a chassis repair manual with rear suspension diagrams for a p-30? I was thinking that the axle may have been knocked back but I can see that the axle is directly below the bumpers.
Old 12-08-2005, 09:39 PM   #4
1977 28' argosy moho
scarborough , ontario
Hi Stantank, sorry to hear you're having problems with your motorhome. I have a 1977 Argosy 28 footer and I'm going to get you some pictures of my setup. I don't have any airbags in the rear of my Argo but I do have a big honkin' stabalizer bar. I think my setup is as original since the PO did a pretty good job of not "customizing" when he maintained things. Hopefully I'll have more info for you on the weekend.
Warbs is offline   Reply With Quote
Old 12-10-2005, 05:43 PM   #5
1979 28' Argosy 28
Cullman , Alabama
Thanks for your concern Warbs. I’m looking forward to the information.
Stan
Old 12-10-2005, 07:54 PM   #6
Pictures...maybe
Here are a few pictures I took of my rear suspension. The rear stabalizer bar extends about an inch and three quarters through the bushings. It's pretty grungy under there since I sprayed rustproofing around and my rear axle bushings weap a bit.
Old 12-10-2005, 07:56 PM   #7
no pictures yet
Sorry but my pictures were too big to post. I'll redo them at a poorer quality tomorrow...unless someone knows how to get around the posting rules.
Old 12-10-2005, 08:34 PM   #8
I'll try again
Old 12-11-2005, 08:42 AM   #9
1979 28' Argosy 28
Cullman , Alabama
Man you have help me more than you know. I am now thinking that someone has cut the bar off about 3”. If I could figure out how to post my photos you could see what I’m talking about. The bar has torch marks indicating a cut on both ends. Should I have an extension welded on or look for a replacement
Old 12-11-2005, 08:44 AM   #10
Somewhere , Indiana
Exclamation Replace
To the best of my knowledge the bar is spring steel. The torch (previous owner) or welder (you) will ruin the temper of the steel!
Regards,
Henry
axleman is offline   Reply With Quote
Old 12-11-2005, 11:45 AM   #11
1979 28' Argosy 28
Cullman , Alabama
That don’t sound good! Any idea where I could find a good used bar?
Old 12-11-2005, 12:00 PM   #12
Somewhere , Indiana
Cool Wow!
Stantank,
I assume that you are talking the Chevrolet P-30 chassis – very popular chassis for may years. Prior to axles I was an RV Engineering guy. I would look to ebay. If that fails – look for a front end totaled motor home that can be a donor.
Additionally – P-30 chassis manuals are available. I just sold a set on ebay (I know you didn’t want to hear that). They are out there. Happy hunting.
Good luck my friend!
Best Regards,
Henry
Old 12-11-2005, 02:07 PM   #13
_
stantank and others
man that's weird....why would anyone cut off the ends? anyway lots of p-30s out there so lots of spare parts....naturally the junk yard would be a place to prowl....many now have online inventories.
my suggestion is get a stiffer aftermarket replacement and polyurethane bushings.....did this on mine and really helped the handling.....a small increase in diameter or moving to cromoly steel make a much stiffer bar.
very little lean on corners and exit ramps is amazing for a moho.
cheers
2air'
Old 12-11-2005, 04:07 PM   #14
1979 28' Argosy 28
Cullman , Alabama
Thanks everyone!
I will start looking around the junk yards for a good one tomorrow. I appreciate all the feedback and the photos.
Leak at rear bedroom wall Kirby Stone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 02-12-2010 11:41 AM
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 08:52 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Leak in the rear JodynJeep Sinks, Showers & Toilets 10 09-08-2006 09:40 AM
