Old 10-07-2004, 03:51 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Exclamation Rear fuel pump fuse
There is no voltage to the rear fuel pump when the key is on. I'm thinking it may be a fuse. Can someone tell me where to look for this fuse?
I was stuck on the side of the road for a couple of hours due to this problem, then coachnet towed me to a small shop who knows nothing about MHs. He's going to look at it some more tomorrow... I sure would like it to be a fuse.
guy99 is offline   Reply With Quote
Old 10-07-2004, 04:39 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by guy99
There is no voltage to the rear fuel pump when the key is on. ....... Can someone tell me where to look for this fuse?........
There may by an oil pressure permit switch on the engine (mine is located at the streetside front of the engine, just above the oil pan, adjacent to the oil pressure sending switch).
The fuel pump was installed by Airstream, so the mechanic will find no reference to it in the Chevy literature.
There (supposedly) has to be oil pressure in order for the pump to run, but on mine (when I first purchased it) it would run when the ignition switch was turned to the "on" position.
Be sure to change all of the fuel filters - one just before the electric pump, one in the area of the steps/battery box, and one internal to the carburetor.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 10-07-2004, 05:33 PM   #3
guy99's Avatar
Images: 16
Unfortunately I'm under the weather and not up to crawling around under the MH. I will pass this infomation on to the mechanic. He looked at all of the filters and said they were very clean.
Help - MH Can't climb hills swebster Mechanics Corner - Engines, Transmission & More... 76 06-11-2008 08:17 PM
Fuel pump redynvre Mechanics Corner - Engines, Transmission & More... 23 09-20-2004 04:54 PM
Adding External Fuel Pump smily Mechanics Corner - Engines, Transmission & More... 7 04-07-2004 04:00 PM
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 04:35 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
