Old 12-10-2012, 07:43 AM   #15
2000 31' Land Yacht
Fort Erie , Ontario
I can only relate my experience. Am very happy with mine that have been in for 1+ years. The threads on the bleeders come preloaded with thread sealant. If for some reason the sealant was removed (bleeders reinstalled several times) it could cause air to get in during bleeding process. Their site has complete instructions and offer the sealant as well.
Steve
is.chowa is offline   Reply With Quote
Old 12-10-2012, 11:50 AM   #16
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Actually the problem with mine was not around the thread. The bleeder it self leaked through the check valve. When I tried it after I took it out I found that the check valve was not working at all, so it acted just like an open bleeder. After that I just didn't trust them to work all the time.
I previously had purchased a hand vacuum pump (Mighty Vac) and went with the gravity/suction method of bleeding. This method has worked fine for me for years and no chance of a screw-up introducing air. Not saying that the speed bleeders don't work well when they're not leaking. Just had the one failure that caused me to go back to what I know worked well. They were Russell Speed Bleeders by the way.
92landyacht is offline   Reply With Quote
Old 12-11-2012, 08:54 AM   #17
2000 31' Land Yacht
Fort Erie , Ontario
Speed Bleeder is a trademark of speedbleeder.com. Not sure if yours were from the same source. Anyway, they produce these for many many vehicles including the P32.
Steve
Old 10-15-2013, 09:50 AM   #18
Nampa , Idaho
What is the part number for the speed bleeders for the P32 chassis?
LarMar is offline   Reply With Quote
Old 10-16-2013, 10:08 AM   #19
2000 31' Land Yacht
Fort Erie , Ontario
Here is the contact info: Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder or For applications not listed call 888 879 7016 or e-mail your request at speedbleeder@earthlink.net
Listed under Chev/GM P30
Steve
Old 10-16-2013, 10:19 AM   #20
2000 31' Land Yacht
Fort Erie , Ontario
Just a note on the ATE SuperBlue brake fluid. Seems that DOT finally figured out that the fluid is blue which goes against the DOT standard that brake fluid should be clear or light straw color and has been delisted and as far as I know is no longer available.
