02-05-2017, 08:06 AM
#21
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands
Originally Posted by mayco
I'm about to change the oil in my differential, do you fellas recommend using any product in addition to the gasket on reassembly? Ive read about spray-on gasket sealer and others but is there a general consensus for the differential gasket? Is the gasket sufficient by itself? Thank you for any guidance!
Mike
I have been changing my diff for 20 years every 60,000 miles I have a 1997 F-250 7.3 with 351,000 miles and I use only RTV silicon from local parts store and never have a leak ans works well. Meany mechanics use this for many install inplace of gaskets.
02-05-2017, 08:21 AM
#22
2013 31' Classic
billings
, Montana
Originally Posted by BIGED52
It has been my experience when the ring gears are whining or chattering is heard it is time for a full rebuild or rear end replacement! Not a cheap fix at all. When you do this or pay to have it done use a good quality synthetic gear lube differential oil. My GMC 1/2 ton Pick up is currently having loud gear chattering and the rebuilt rear end being put in tomorrow will cost me about $650.00 with the install labor. I just had new brakes and rotors on all four wheels done for $450.00. Lucky the shop will move the new rear brake assemblies to the rebuilt axle. Ed
Why are you replacing your housing ? your diff can be rebuilt without changing the housing,just remove and replace...
02-05-2017, 09:49 AM
#23
1995 25' Excella
xxxxx
, xxxxxx
One of my two rear end replacements required a new center housing. The original one had expanded from heat from when the pinion bearing burned up.
02-05-2017, 07:34 PM
#24
2003 25' Safari
Riverside
Thanks for all the information fellas. The few times Ive changed rear end oil in the past there has always been a drain plug in the cover. I was pretty surprised to find that there wasn't one in this cover. I get it, it forces you to inspect the innards. The oil looks and smells ok but I'm just not sure when it was changed last. I think it has been serviced at least once though because I can see some black gasket material that oozed out around the edges. I don't suppose that would be an OEM install.
Mike
Dodge/ram has always used a silicone sealer on its trucks with Dana diffs,it is formulated specificly for use with diff fluids
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
02-14-2017, 09:16 PM
#25
Foothill Ranch
I used to get this whine on one side or the other quite regularly.
It would change side if I was driving in the UK or Europe.
Finally I figured it out.
After I divorced, it never happened again.
02-14-2017, 10:58 PM
#26
2007 22' International CCD
Corona
SFX: Rimshot!!!
02-15-2017, 05:11 AM
#27
1982 31' Airstream 310
champaign
Too funny !!!!!!!!! bada-boom!
03-11-2017, 09:30 PM
#28
Kelseyville
I'm in the process of chainring my rear differential oil as well. Does the stock rear end in a 1981 Excella come with posi traction? I ask because if it does I know I need to include the additive in with the gear oil.
Erny
"Electra"
1981 Airstream Excella 28' Turbo Diesel
Northern California
03-11-2017, 11:53 PM
#29
1982 28' Airstream 280
Port Angeles
No it's a Dana 70 HD non posi.
Cheers, Dan
~ Margaret Thatcher ~
03-12-2017, 09:57 AM
#30
Kelseyville
Thanks!
-Erny
"Electra"
Northern California
03-12-2017, 12:57 PM
#31
Port Angeles
I may have misspoke. If you have rear disc brakes you have the Dana 70 HD. If you have rear drum brakes I believe it is a Dana 70. It still should be non posi.
Cheers, Dan
03-13-2017, 09:52 AM
#32
champaign
I ended up using just the gasket, torqued to spec and have done a few hundred miles..no leaks. Synthetic.
03-13-2017, 10:06 AM
#33
Kelseyville
I have Disc Brakes in the Rear 👍🏽
-Erny
"Electra"
Northern California
