Old 05-15-2007, 05:14 AM   #15
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
New fused line to air pump
The OEM line to the compressor was way to small for my liking. Also all the way to the front of the coach was quite a voltage drop.
I have run a 6 gage line from the house bank, and protect it with a 30 amp fuse. I have a relay by the compressor that still works off the line going back, and that is what supplies the power to the relay. This way no load on the OEM line and it still works on the ignition switch.
Here is a couple of shots of the set up.
Thought I had some shots of the battery and fuse hook up. Will have to get that from the home computer. Not on my Memory chip!
ID:	37384   Click image for larger version
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Rear Air bags PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 24 11-12-2007 06:02 PM
Air Horns aren't working kzener40 Airstream Motorhome Forums 21 06-12-2005 07:26 PM
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 07:12 AM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Air pressure for winterizing montanaandy Winterizing, Storage, Carports & Covers 10 09-23-2002 05:13 PM
