Old 05-08-2012, 09:49 AM   #1
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
rag joint
Our 1984 310 got stuck in a shop instead of storage at the end of our last trip. Wanted the brakes because they were pulling to the right. They said that the "rag joint" connecting the steering column to the steering box is dangerously worn out, and were not able to find a new one before we had to fly home. Apparently the column and joint are NLA, and the one substitute joint they ordered (looked like a mini driveshaft, two piece with a splined joint in the middle) was two inches too long. Anybody have a source?
Waipio Rim is offline   Reply With Quote
Old 05-08-2012, 11:45 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Try CPP. Look this over...they are a source of the info you wand....maybe even the Rag Joint/http://www.classicperform.com/tech_articles/ColumnInstructionguide.pdf
Old 05-08-2012, 12:18 PM   #3
Waipio Rim's Avatar
Honokaa , Hawaii
Thank you very much, found a page in their catalog that looks like it has anything that could be needed for this fix, Steering Shaft Components From Classic Performance Products
Sent the link to the shop.
