Old 02-08-2012, 10:48 AM   #1
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
Radiator - Is this right?
I have a 76 Argosy MH with a 454 in it. I need a new radiator. I'm having issues finding one. Before I get one I need to make sure what I have is correct or if it has been rigged.
Does the attached picture look correct?
Any suggestions on a where to get a new one. I've read all the posts and searched the Inet for hours. Nothing concrete. I do have 1 vendor working on it.
Jason
MrJ is offline   Reply With Quote
Old 02-08-2012, 10:57 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
With the bracket attached to the fill spout, I would guess it's original. But, that's really just a guess.
Have you tried a radiator shop? They should be able to pull the radiator and install a new core in between the tanks, assuming that the tanks are still good. The top tank in the picture looks like its a metal tank that could have a new core soldered to it. You could save a good chunk of money if you pull the radiator out yourself, if you want to tackle that job that is.
Good luck with whatever you decide to do!
Chris
Old 02-08-2012, 11:01 AM   #3
Jason
Jason.
You should be able to get the radiator recored.
When you reinstall it, move the transmission oli cooler away from the front of the radiator.
You can locate it behind the bumper.
Why cool the transmission oil, and put all that extra heat back into the radiator?
Old 02-08-2012, 11:05 AM   #4
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
I think it's leaking at the top.
Is re-coring a temporary fix?
I'm going to pull it out myself. JOY! Front is off the MH. (2 day job)
Old 02-08-2012, 01:05 PM   #5
345bill's Avatar
Las Vegas , Nevada
Yours looks like it has a new hose at the fill spout and the picture shows it was leaking in that area but even if it is leaking where the nipple goes into top tank they can easily repair that when re-coring. When you bring the old one to the shop they'll show you what will be changed to make it as a new one.
Since many of these are unique to each different model/year re-coring is your best option in my opinion.
345bill is offline   Reply With Quote
Old 02-08-2012, 03:11 PM   #6
1982 28' Airstream 280
Redwood City , California
Jason
This is the same as my AS 280 '82
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 02-08-2012, 03:26 PM   #7
r carl's Avatar
Lin , Ne
Re-coring will restore to as new condition if they use a core made in the USA.
Old 02-11-2012, 11:17 AM   #8
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
I struck out. I'm going to take it to a local shop and have them fix it.
Would it be better to tell them to re-core it or "fix" it? I think the top tank leaks.. If there is scale/lime build up can they chemically clean and make it new? Or is it best to get a new core?
I don't want to be in the middle of Wyoming and lose the radiator.
Old 02-11-2012, 01:02 PM   #9
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Originally Posted by Inland RV Center, In View Post
Jason.
That has always been my question! Not much room in a Buick to do that but I'm considering relocating mine.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 02-11-2012, 01:07 PM   #10
FreshAir's Avatar
1966 24' Tradewind
I had another radiator built for both my convertible and pickup. A 4 row for the convertible and a high effecient core in the truck. If your radiator has to be taken out ask if such an upgrade will work. The cooling differences in mine were WELL worth it.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 02-11-2012, 01:11 PM   #11
howco's Avatar
1970 27' Overlander
Sumner , Washington
the top and bottom tanks are solid brass and don't really wear out, a decent radiator shop will remove the core and install a new one between the top and bottom tanks and hand it back to you.
I also agree with the advice on buying a new transmission oil cooler and remounting it away from the radiator.........
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Old 02-11-2012, 01:31 PM   #12
Neil
Just so the cooler can get some ram air.
Old 02-11-2012, 02:49 PM   #13
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Even if it is only leaking at the top, have it re-cored while you have it out. A good radiator shop will hand you back a radiator as good as new. Ask your local mechanic where he sends stuff. Ask several if you can. The last thing a mechanic wants to do is to have to do a job over and if they are happy with the work of "Acme" radiator shop I would go with that. If you don't have a mechanic, ask the counter guys at your local NAPA store. These guys know all the shops in town and should be happy to point you in the direction of a good shop.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is online now   Reply With Quote
Old 02-28-2012, 11:10 PM   #14
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
Thanks for the help. I had it re-cored. It was the only option. Should be good as new I'm told. Ac condenser had a hole, that's fixed.. I should be good $450 later... Price sucks but I feel better about not getting stuck and overheating. I'm putting a 180 thermostat in there now.
