Old 01-12-2018, 11:16 AM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Radiator hose clamps
Since it looks like I'll be pulling my radiator (again), I'm hoping for some recommendations on the best type of hose clamps for the reinstall. I don't want to use the cheapo clamps off the rack and would like something more substation.
What type do you fellas use for this and where do you typically buy them. I know there are a few different styles, can you give me your preferences?
Thank you fellas.
Mike
mayco is online now   Reply With Quote
Old 01-12-2018, 12:32 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I like tower clamps or dual wire clamps.
CRH is offline   Reply With Quote
Old 01-12-2018, 12:54 PM   #3
2007 22' International CCD
Given space and access, stainless steel worm-gear clamps. Have found the wire ones flat not reliable when reused and tend to wear groves in the hoses, and I snag myself on their wire ends.
Old 01-12-2018, 01:46 PM   #4
mayco's Avatar
Ive seen one type worm drive where the slots were raised on one side for better grip. I think they may be OEM for some BMWs, don't know what they are called.
Thanks for the input so far!
Old 01-12-2018, 01:49 PM   #5
mayco's Avatar
Like these
Old 01-12-2018, 02:04 PM   #6
Boxite's Avatar
2008 22' Sport
Aircraft quality and won't cut into the hose: http://www.aircraftspruce.com/catalo...ickkey=3009104
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 01-12-2018, 04:48 PM   #7
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Mike, look for T Bone clamps......done ! Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 01-12-2018, 05:36 PM   #8
1981 31' Excella II
New Market , Alabama
The standard Aero-Seal clamps are what I would use. I hate the spring loaded things. Some of those just barely release when it is at the stop and are hard to get the hose off. The Aero-Seal clamps don't seem to work as well on small diameter hoses because the compression relaxes as the rubber takes a set. On radiator hoses, I never had a problem with them.
Mcmaster.com has everything but I bet you can get them cheaper on Amazon. Mcmaster better quality though.
Perry
Old 01-12-2018, 06:21 PM   #9
mayco's Avatar
Are those what you use Bob?
Old 01-12-2018, 07:00 PM   #10
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
If your Rad has plastic tanks and outlets DO NOT use anything but the factory style spring clamps.
The Factory spring clamp put even pressure on the hose and as the hose takes a set they maintain even pressure. You can buy a special tool that makes them easy to use otherwise its a pain.
Other types of clamps put uneven pressure on the hose and rad neck and will cause the neck to deform and even crack.
This is the tool you want. you can get it from Amazon , Sears and auto parts stores
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 01-12-2018, 07:13 PM   #11
bobmiller1's Avatar
Yes Mike, let me know if you have trouble finding them. Regards, Bob
Old 01-12-2018, 07:16 PM   #12
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Mike, your rig deserves only the best that this world has to offer; nothing less will do for Allison....
https://www.ebay.com/itm/12-Adel-Wig...-/221996218662
http://www.hrpworld.com/store/defaul...couplings.html
Cheers
Tony
Old 01-12-2018, 08:40 PM   #13
1981 31' Excella II
My experience is that plastic radiator tanks will eventually crack. I expect you don't have plastic tanks. I ended up putting an all aluminum radiator in my Eclipse when the old tank cracked along the top. Just make sure that if you are using a hose barb that they are metal and not plastic. The plastic will compress and the hose will come off.
Perry
Old 01-13-2018, 07:44 AM   #14
mayco's Avatar
Cheers
Tony
HAHAHAHAHAHAHA! Are they jeweled also? Or at least bedazzled
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 01:53 PM
Pex- Clamps or Rings VeggieBullet Plumbing - Systems & Fixtures 68 02-17-2016 05:22 PM
Broken clamps/regulator bracket on 1972 trade wind Maggiefoss LP Gas, Piping, Tanks & Regulators 0 09-09-2012 01:46 PM
Window clamps FrankR Windows & Screens 5 12-02-2002 04:48 PM
