01-12-2018, 11:16 AM
1982 31' Airstream 310
champaign
Radiator hose clamps
Since it looks like I'll be pulling my radiator (again), I'm hoping for some recommendations on the best type of hose clamps for the reinstall. I don't want to use the cheapo clamps off the rack and would like something more substation.
What type do you fellas use for this and where do you typically buy them. I know there are a few different styles, can you give me your preferences?
Thank you fellas.
Mike
01-12-2018, 12:32 PM
1995 25' Excella
xxxxx
, xxxxxx
I like tower clamps or dual wire clamps.
01-12-2018, 12:54 PM
2007 22' International CCD
Corona
Given space and access, stainless steel worm-gear clamps. Have found the wire ones flat not reliable when reused and tend to wear groves in the hoses, and I snag myself on their wire ends.
01-12-2018, 01:46 PM
champaign
Ive seen one type worm drive where the slots were raised on one side for better grip. I think they may be OEM for some BMWs, don't know what they are called.
Thanks for the input so far!
01-12-2018, 01:49 PM
champaign
Like these
01-12-2018, 02:04 PM
2008 22' Safari
Spicewood (W of Austin)
01-12-2018, 04:48 PM
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Mike, look for T Bone clamps......done ! Regards, Bob
01-12-2018, 05:36 PM
1981 31' Excella II
New Market
, Alabama
The standard Aero-Seal clamps are what I would use. I hate the spring loaded things. Some of those just barely release when it is at the stop and are hard to get the hose off. The Aero-Seal clamps don't seem to work as well on small diameter hoses because the compression relaxes as the rubber takes a set. On radiator hoses, I never had a problem with them.
Mcmaster.com has everything but I bet you can get them cheaper on Amazon. Mcmaster better quality though.
Perry
01-12-2018, 06:21 PM
champaign
Are those what you use Bob?
01-12-2018, 07:00 PM
1969 25' Tradewind
Shasta Lake
If your Rad has plastic tanks and outlets DO NOT use anything but the factory style spring clamps.
The Factory spring clamp put even pressure on the hose and as the hose takes a set they maintain even pressure. You can buy a special tool that makes them easy to use otherwise its a pain.
Other types of clamps put uneven pressure on the hose and rad neck and will cause the neck to deform and even crack.
This is the tool you want. you can get it from Amazon , Sears and auto parts stores
01-12-2018, 07:13 PM
north blenheim
, New York
Yes Mike, let me know if you have trouble finding them. Regards, Bob
01-12-2018, 07:16 PM
Dazed and Confused
Hillsburgh
, Ontario
Mike, your rig deserves only the best that this world has to offer; nothing less will do for Allison....
https://www.ebay.com/itm/12-Adel-Wig...-/221996218662
http://www.hrpworld.com/store/defaul...couplings.html
Cheers
Tony
01-12-2018, 08:40 PM
1981 31' Excella II
New Market
, Alabama
My experience is that plastic radiator tanks will eventually crack. I expect you don't have plastic tanks. I ended up putting an all aluminum radiator in my Eclipse when the old tank cracked along the top. Just make sure that if you are using a hose barb that they are metal and not plastic. The plastic will compress and the hose will come off.
Perry
01-13-2018, 07:44 AM
champaign
Originally Posted by Isuzusweet
HAHAHAHAHAHAHA! Are they jeweled also? Or at least bedazzled
01-13-2018, 07:46 AM
champaign
Thanks for all the recommendations fellas...I think I'll look into the T-bolt style.
Thanks again.
01-13-2018, 08:51 AM
Tampa
Stainless hose clamps. On most, the strap is stainless but the worm gear isn't.
The most important thing is don't over tighten them. You don't want the rubber squishing out of the slots.
