Old 02-07-2018, 10:34 PM   #43
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I think you may be a little optimistic there Tony. This is from my book.
The turbo bump is probably 15-20hp however I have never seen a number published or posted anywhere officially.
Cheers, Dan
~ Margaret Thatcher ~
Old 02-07-2018, 11:21 PM   #44
Interesting...
I looked up the engine number and very little came up but this...
https://www.smokstak.com/forum/showthread.php?t=166708
Also saw references to a 6BD1T.... is that similar??
One guy said this...
Somewhere else I found some power figures:
6BD1 NA 5.785 litre: 160 HP
6BD1T: 175 HP
6BG1 NA 6.494 litre: 175 HP
Here...
http://www.4btswaps.com/forum/showth...hp?16869-6bd1t
Actually, digging around in the 4BTswap site is cool...
Good info on the Isuzu engine buried there... like this one...
http://www.4btswaps.com/forum/showth...-6BD1T-wake-up
Old 02-08-2018, 08:20 AM   #45
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Attachment 303750
Dan, I see your 130 hp, 253 ft lbs and raise you to 145 hp, 289 ft lbs based on this Airstream brochure
Diesel motorhome standard specification 2- Airstream.
Doesn't mention anything about a turbo though.......maybe turbo is 160 hp?
Sorry, couldn't copy link....on my phone and don't know how.
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 02-08-2018, 08:27 AM   #46
Put pretty much all day into the updates yesterday.
Tried to add info on the 454 that is fair and balanced, provides a reference point.
Any errors, comments or advice?
Old 02-08-2018, 08:57 AM   #47
The book I posted is an Isuzu book. I think the 165hp might be Airstreams guess with the BAE turbo.
Cheers, Dan
Old 02-09-2018, 01:01 PM   #48
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
This is a pretty good overview of the 6bd1A (marine) and the 6bd1T, including their differences.
https://itstillruns.com/specificatio...e-7769459.html
mayco is offline   Reply With Quote
Old 02-09-2018, 05:12 PM   #49
Thatís awesome, solid info Mayco.
Interesting to read that the T version and the Cummins 6bt are pretty darn close in capacity, size, weight, and output.
Old 02-09-2018, 10:05 PM   #50
Added info, and opinion about the 454, and mods to it, to gain MPG and power.
I guess it makes sense in my mind to keep what you have until it expires, or the Lottery numbers come up...
Added some info and observation about Cummins engines.
Know mech issues with the BT series, like KDP, and lift pump failure.
VE-Pump, and P-Pump pros and cons.
Power levels as stock and tuning.
Its gonna get DEEP, which is only important if you REALLY want to know!
Will summarize and add info on the Isuzu tomorrow I hope.
Old 02-12-2018, 11:12 AM   #51
Added a link to these guys, who have great info and parts.
https://www.dieselconversion.com/blo...e-Information/
Old 02-13-2018, 08:19 AM   #52
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
Well I can add a little:
TFI was the best money ever spent: A LOT more power, MPG from 4 to 7.5.
When the Allison 545 smoked I replaced with a 4L80e. Motor had 85,000 and needed rebuilt. No better MPG.
Rebuilt 454: .25" stroke, hdy roller cam.... 10 MPG and LOTS more power. Then 2000 miles out while in New Mexico dropped valve and killed motor. After I paid over $8K to have it rebuilt there, was back to 6.5 mpg and no power. Note: could not get air/fuel ratio below 19/1. Bought totally programmable computer. was going down the road trying to program when it died...... I call AAA and started looking for a Cummins 12V.
Cummins: 4L80e just would not work behind the Cummins which brought me the Allison t1000 6 speed.
I have run one tank full so far and with a lot of turbo leaks (now fixed I hope) and the injectors were all bad (new injectors now) it got 9.6 MPG
I keep having medical setbacks. Blow my right knee out the first of December. So, as soon as I can recover from a total knee replacement 27Feb I'm going to be off.
choctawmel is offline   Reply With Quote
Old 02-13-2018, 09:01 AM   #53
Putting a Diesel in your Motorhome.
I knew your input would be valuable and valid, Mel.
I need to go back and read through your thread, and take some notes.
The one thing I stated before, that I kinda knew but had not rationalized was that simple exhaust manifold issue.
Over in the thread I started in the 4BT Swap Forum, very early on, someone commented on the pictures I posted of know Cummins fitments, was that the Turbo was high mounted on The OEM Airstream/Cummins 345, and and low mounted on GWBakerís conversion. I just didnít know, or grasp, what that meant, and it was only when I got my own Cummins motor and kinda mocked the head, exhaust and turbo up on the bench, it hit me. It was then that I understood why your first turbo install fouled the floor, and all the work you went through as a result.
If this thread saves one converter what you went through it will have been worth it.
I also felt the need to point out the difference between VE-Pump, and P-Pump, from a fitment, and power perspective.
There will be a bias toward Cummins engines, for the simple reason that itís been done more than the others.
At the moment, I am still gathering info on the several Duramax conversions, and will be posting what I have learned.
Whilst itís obvious that this can, and has been done, am learning about the pros and cons.
I also want to add any other Diesel
Swaps, like the 7.3 IDI that just came to our attention.
Old 02-13-2018, 09:24 AM   #54
Huntington Beach , California
Hello. Iíve bought a 7.3IDI Airstream Swap with a e4od. I will start the next weeks diving into it. I drove it from Portland to corona, ca. On the flat California area I got around 15 (!) mpg. In the mountains around 10. On thing to consider is the enormous amount of noise. I will have to tear the front apart to install everywhere from inside noise insulation. But on the other side - even without working OD, 70mph are possible.
clemensk is offline   Reply With Quote
Old 02-13-2018, 09:55 AM   #55
Awesome Clemensk!
Im in OC too, and my 345 is over in storage in Riverside.
Lets connect via PM and exchange info, as Im sure I will be able to give you knowledge and insight into your new project!
Old 02-13-2018, 03:49 PM   #56
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
The export version of the 250 Classic was only (as far as I am aware) available as a diesel option. I think it was available as a stock 6.2L diesel with the 4L80E overdrive tranny so that was available from the factory until 1993.
Nick
PS Maybe snag a pint when you come back
Boom Sounds is online now   Reply With Quote
HELP! Accidentally putting E-85 instead of diesel in AI roadmama Sprinter and B-van Forum 66 11-29-2015 05:31 AM
Another reason to keep your Airstream Diesel Motorhome frankandsue Airstream Motorhome Forums 5 09-23-2010 06:21 AM
Putting AS on Blocks/ Electric brake conversion ? airhead Axles 4 06-27-2004 03:52 PM
Putting my trailer undercover Stefrobrts Our Community 32 02-05-2004 08:57 AM
Putting in new carpet wardster All Argosy Trailers 1 02-03-2004 12:02 PM
