Old 01-15-2015, 05:48 AM   #225
Mel, that's a real bummer
Had the exact same thing happen to our Spitfire race engine. Not a pretty sight. Turns out the valve guides weren't reamed to the right size for the valve stem
Hopefully you won't be stuck there to long and keep us updated on what happens.
Good luck!
Old 01-15-2015, 06:04 AM   #226
1981 31' Excella II
New Market , Alabama
Who rebuilt the heads? I think I would go with a crate motor and stop messing around with this one.
Perry
Old 01-16-2015, 11:49 AM   #227
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
Machinist got the bock/heads vatted/cleaned and checked. The scratch in #7 cylinder IS a cracked.
Checked with dealer for new GM block $2K, long block $6.5K. Don't think so.
I ordered all the parts to use the block I got with one sleeved cylinder, all bored to .040 over- 496cid
I'm thinking the machine shop I used when I build the stoker was not as good as it used to be. Exhaust valve guides should of been replaced; side gap on piston to cylinder walls are max.
All this because a couple 75 cent parts failed.
choctawmel is offline   Reply With Quote
Old 01-18-2015, 03:25 PM   #228
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Oh that empty feeling I have
Going on week three being powerless in Las Cruces
Old 01-18-2015, 06:37 PM   #229
1981 31' Excella II
The only reason for valve guides to seize is they were too tight which is hard to believe on a used motor. They could have forgotten to put lube on the valve guides. You may have some sort of oil delivery problem as well. The only way a valve should cause problems is a broken spring or over revving the engine. I don't trust anyone with engine rebuilds till I have checked the work myself. I have never seen it done right. You probably have a two or three crate motors in cost and aggravation with what you have.
My boss use to live in Las Cruses. I can ask him if he knows someone trust worthy there if you like.
Perry
Old 01-18-2015, 07:03 PM   #230
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Pully that 454
My guess is that the number seven piston failed and took out the valve instead of the other way round...
Might be wrong, but my experience with 454s is that piston failure is relatively common when compared with other catastrophic failures.
Additionally, I am not a fan of big strokers when reliability is important. Strokers usually require some compromises in the piston design that don't always translate well with regard to reliability in towing and such.
I am about sure that a 454 Mark IV with early large port heads will make more power than a 500 cu in stroker with late peanut port heads.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 01-18-2015, 09:09 PM   #231
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Did the engine pop going up the hill west of Las Cruces?
Old 01-20-2015, 08:34 AM   #232
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Didn't make it west of town. Started knocking 2 miles east of the I-25/10 junction.
Before it was all torn down, thought the valve stuck. BUT, the valve pulled thru the lock. Valve stem is badly worn. So, it did something I or anyone I've talked to ever heard of before. The rocker arm was still on the spring retainer.
The wear on the valve/lock left junk in the pan. May be the reason I had lost power and mpg (I thought it was the head wind)
Valve driven into piston. Other piston shows FOD from debris that crossed over the intake.
So, when the parts arrive, This will be 496cid, 0.250" stroked, 0.040 bored, 8.3/1 compression, hydraulic roller cam monster.
If it don't last longer then 2000 miles this time, it'll be a 12 valve diesel.
Old 01-20-2015, 11:36 AM   #233
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
If it were me, I'd put in one of these bad boys and forget it for a very long time:
HT502 Big Block Crate Engine | Chevrolet
92landyacht is offline   Reply With Quote
Old 01-20-2015, 11:10 PM   #234
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
That sure is a good old days power curve!!
Old 01-21-2015, 06:26 PM   #235
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
that's what I built except I didn't bore it that much
Old 01-21-2015, 06:43 PM   #236
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Went by the builder today thinking maybe the killed valve wasn't getting oil, but not the case.
This trip it had started using oil. I looked at the pistons and rings only to realize the I made another grave error as I intrusted the ring gap grinding to the machine shop I used and I didn't recheck. Looks like the gap closed damaging the piston grove. I should have waited till I wasn't taking so damn many pain pills to put this together. The dropped valve? Why?? But blown out ring groves, my fault.
Least I'm not dealing with this problem
Old 01-21-2015, 09:23 PM   #237
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Too big of a ring gap,,, doesn't really matter... Too small a gap big problem.
After you mentioned the piston failure, I am even more sure that the piston took out the valve and not the other way round.
It would only take a small piece of a ring land to get between the piston and the valve, to bend the valve stem, and start the cycle of destruction...
Old 01-21-2015, 09:26 PM   #238
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Pully that 454
I am about sure that debris did not cross through the intake from one cylinder to the other, but pieces of the ring lands caused the damage in separate cylinders.
By the way,,, is the trailer with the piano on top in Las Cruces?
I have seen the picture before, but I didn't know this piece of rolling art was (maybe) in LC.
