Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 10-05-2004, 11:00 AM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Proper Front Support Point for Chassis
Hi all, I need to spend some time under the front of my 84 310 Limited MH. Where should I place my 3-ton jack stands to properly support the front end?
guy99 is offline   Reply With Quote
Old 10-05-2004, 11:41 AM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by guy99
......properly support the front end?
I put mine on the frame, as close to the jacks as I could.
If you do the rear, be sure to use more than one pair in the rear, as I have found on the 345 there is excessive "flex" in the unit if utilizing only one support point.
I also leave just a bit of weight on the jacking system, just for safety.
If you are going to take the front jacks off, or work on them while they are raised, I would also support the front of the frame, in the area of the front wheels.
Name:	Front Jackstand Support.JPG
ID:	8987   Click image for larger version
Name:	Rear Jackstand Support.JPG
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 10-05-2004, 05:54 PM   #3
zamboni's Avatar
jackstand placement
I put mine under the frame rails, depending on where/ what I am working on. To remove front wheels, I have put them under the frame while supporting lower A frame with another jack stand or solid block of oak. I would caution against using jack stands on asphalt or gravel, they should always be used on level concrete surface.
zamboni is offline   Reply With Quote
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
front suspension/ ball joints wb13798 Mechanics Corner - Engines, Transmission & More... 13 11-07-2003 07:57 AM
front end bottoms out!!? Curtis-79MH Airstream Motorhome Forums 18 09-15-2003 10:13 PM
Front Travel lounge Assembly gvanman General Interior Topics 4 07-17-2003 09:58 AM
Idler arm support assembly PeterH-350LE Mechanics Corner - Engines, Transmission & More... 0 09-11-2002 08:53 PM
