Old 04-02-2012, 07:33 PM   #1
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Proper air bag mounting for 24' A/S MoHo?
Can anyone help me determine if this is a standard air bag installation on a 24' MoHo? It appears there is a factory made bracket mounted inside the frame rail and a homemade bracket just below it welded to the bottom of the frame. I was going to replace the air bags but, now I am wondering if someone has modified this install . I'm not sure if these are even the correct air bags for this install. Has anyone else replaced the airbags on a 24' Moho, if so what was the part # for the Firestone Ride-rite?
Name:	AIRSTREAM REAR END 010.JPG
ID:	154875   Click image for larger version
Name:	airstream shocks and airbags 001.JPG
Name:	airstream shocks and airbags 012.JPG
ID:	154877   Click image for larger version
Name:	airstream shocks and airbags 017.JPG
Gregsch is offline   Reply With Quote
Old 04-03-2012, 01:31 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I believe the air bags on your coach are a booster rather then a "air" suspension. Check out this site.
Air Lift Company LOADLIFTER 5000; LEAF SPRING LEVELING KIT - All Drive Types
This is a similar type of installation. There are several outfits offering similar products that do the same thing, The air bags may fit your mounts but many times the kit comes with mounts that may be easy to install.
This outfit has new installation kits as well as replacement parts.
Ride-Rite Replacement Air Bags, Air Springs - Replacement Firestone Bags
Good luck, Dan
Smartstream is online now   Reply With Quote
Old 05-28-2012, 07:12 PM   #3
Gregsch's Avatar
Tipp City , Ohio
Thanks for the lead on the parts. I went to SD Truckparts. Fair pricing and quick shipping. I bought the whole kit ( Firestone # 2080) because I was not sure about the upper mounting bracket on my MH. After I got the parts in my hand and compared them to what I had I realized that my mounting brackets would work fine. I did not install the brackets or the air lines. I could have saved some money by buying the bags seperately. Oh well , lesson learned. The only issue I had was the bolts on top of the air bags were a little different. The new bags had a coarse thread and a nut whereas, the old bags had a fine thread and a nut with a sleeve. I had to buy a bronze bushing and cut it down to make my old brackets work (no big deal).
ID:	159565   Click image for larger version
Old 05-29-2012, 12:19 AM   #4
Glad it worked out for you. A lot of this stuff is scary until you actually get the part in your hand, then it all comes together.
Cheers, Dan
Old 07-26-2012, 06:46 PM   #5
I put that same kit on a 1976 20' Coachmen motorhome that was sagging in the rear. Seemed to do that job well but you had to manually monitor the air pressure.
The Coachmen motorhome is long gone and I now have a 1974 20' Argosy motorhome that is in need of something similar. What I've been thinking about doing is adding this same kit only with the addition of leveling valves (one per side) and installing an air compressor and tank (salvaged from our parts 345 motor home).
I can't think of any reason why this wouldn't work.
bkahler is online now   Reply With Quote
Sun Screens for the Interstate Brentsouth Sprinter and B-van Forum 21 05-04-2012 11:12 AM
Suggestions for South Carolina RV parks on beach? Lothlorian Airstream Lifestyle 25 04-14-2012 07:36 AM
LED lights for '68 AS thunderbird General Repair Forum 18 04-09-2012 11:52 AM
1966 Vintage 24' Airstream Tradewind Travel Trailer Polished eBay Watch Airstreams on eBay 0 04-02-2012 10:50 AM
Heating/Air on a 2010 International AirHeadRik Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-02-2012 09:24 AM
