Old 03-29-2011, 08:02 AM   #1
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
problem with rear window awning
The cast hook is broken on the rear awning on my 91 350LE.
I found this hook for sale but it does not have holes for 3 rivits. Do you think this is the right size to use on my moho and where can you find these extra large rivits?
I may order this one anyway because I have not seen any others for sale online.
t7389sg is offline   Reply With Quote
Old 03-29-2011, 08:13 AM   #2
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
Call Zip Dee they have the hook and rivets! 2 or 3 rivets?
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 03-29-2011, 08:21 AM   #3
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
That looks just like the hook that Zip Dee uses.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-29-2011, 10:09 AM   #4
That hook comes from Zip Dee.
You can call them at 800-338-BEST.
Ask for Linda.
Old 03-29-2011, 11:32 AM   #5
t7389sg's Avatar
Laurel , Maryland
Thank you Andy. I called and they don't make it with 3 holes any longer but the 2 hole design is the same size and should fit covering the middle hole or I could drill the middle myself. The hook is on the way. Problem solved. Thanks to everyone for your help.
Steve G
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
rear window on a '66 caravel cojer Windows & Screens 3 02-05-2011 01:10 AM
Front and Rear Window hinge - 1968 Randy Gates 1965 - 1969 Globetrotter 1 01-15-2011 10:05 PM
