Old 09-29-2012, 05:22 PM   #1
Power Steering Pumps
I got my December 2012 copy of Car Craft Magazine yesterday...
Low and behold, it has a GREAT article on Saginaw power steering pumps!
Differences, and a basic rebuilders guide, and where to get parts.
It seems that they say that aside from a change from Imperial threads to metric, and the way the pulley is attached, there is little difference between the pumps from 1960 to 2009.
The same reseal kit covers them all and costs $8.
Sounds like a great thing to carry in the spares box!
I suggest anyone with an interest grab a copy, altho, I note that once the magazine hits the shelves, they post the story on their website..
Old 09-29-2012, 06:19 PM   #2
1982 28' Airstream 280
Redwood City , California
Steve,is this the pump in our classics? Mine is leaking. Does this mean they can be rebuilt?
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 09-29-2012, 06:51 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Have you replaced the hoses?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-29-2012, 07:25 PM   #4
I haven't replaced to hoses yet, but it definitely is leaking from the pump. All hoses and fittings are dry. The next morning after getting to Coos Bay it was leaking lots! I think it was the cold weather over night. I added about a pint this morning and drove from Coos Bay to Seven Feathers RV park and level is good. It is dripping just slightly. It will make it home but I will need to fix and replace hoses before next trip!
Old 09-29-2012, 11:55 PM   #5
Yes you can Dean...
Read this one...
http://www.corvette-restoration.com/...mp_rebuild.htm
I found another here...
MattsOldCars.com - American Restoration - Rebuilding a Power Steering Pump
Pump (Saginaw Type)
Starting in 1968, AMC began using Saginaw power steering components. The first cars to get them had 6 cylinders while V8’s began using them in 1972. These pumps are a big improvement over the Eaton units they replaced which are prone to leaks between the reservoir and the pump housing.
These pumps tend to be trouble free but can develop a few problems that require a tear down to repair. Those problems are a damaged reservoir (which causes a leak around the pump body if that area gets distorted), leaks around the hoses and the pump body, and sticky pressure relief valves (which causes either a chirp noise at low speeds or a loss of pump pressure).
The rebuild procedure is very simple (see Tips to make sure your rebuilt pump lasts for a long time prior to heading to the store for parts). You'll spend most of your time cleaning parts. Here’s what you'll need to get before you get started:
  • A 1x2 block of wood
  • A hammer
  • Assorted box and socket wrenches (deep drive)
  • A small flat blade screw driver or pick to remove o-rings
  • A large flat blade screw driver to remove the pump cover retaining ring
  • A small pin punch or large finishing nail (also used during pump cover removal)
  • A torque wrench that will measure up to 35 ft/lbs.
  • A pump rebuild kit (I purchased mine at AutoZone for about $10).
  • Fresh power steering fluid
  • Parts degreaser (Grease cutting dish soap and warm water works well if you’re willing to scrub.)
If you have a press-on pulley, you'll need a removal/installation tool set. Your bigger auto parts stores will usually have a loaner you can borrow.
Before you begin disassembly, I want to warn you about the reservoir on these pumps. They are stamped sheet metal (thinner than a valve cover) and are very easy to bend. Never hit them directly with a hammer. If your reservoir is badly distorted, you can get a new one from a GM dealer (you should take your old one along to make sure the return hose tube is in the correct position) or an AMC parts supplier.
Speaking of reservoirs, Saginaw changed the design of them midyear in `71. The old reservoir is round with a long filler neck. The new design is tear-drop shaped with a very short filler neck. This is the only difference between them.
Disassembly
  1. Drain the pump.
  2. Remove the pulley from the pump. You'll need a special tool for the pressed on pulleys. The bolt on have a nut you need to remove.
  3. Remove the shaft key (pressed on pulleys may not have one).
  4. Remove the brackets.
  5. Remove the studs on the back and the union for the pressure hose. Turn the pump so the shaft faces up and tap on the pump housing to remove the flow control valve and spring. Remove the o-ring from the hose fitting.
  6. Clamp the pump in a vice clamping on the area around the shaft seal and tap around the edge of the reservoir with a block of wood and a hammer to remove the reservoir. Only clamp hard enough to hold the pump in place.
  7. Remove the o-rings from the pump body. There are 4 of them. A large one around the body and 3 on the back where the studs and hose union attach to the pump. Make sure to hold on to the 3 in the back. There are two sizes and you may need to match them up if you are unsure of which ones to use.
  8. Rotate the retaining ring on the pump cover until one end is near the hole at the top of the pump body. Insert a punch into the hole to push the edge of the retainer clear of the pump body and pry the retainer out. There is a spring behind the plate so be prepared to catch it. Chances are, you'll need to tap on the pump body some to remove the plate.
  9. After making sure the key is removed from the shaft, tap on the end of the shaft until the pressure plate, ring, rotor, and thrust plate assembly can be removed. One or both of the dowel pins may come out with this assembly. Separate all of the parts (the pump rotor has 10 vanes in it that will likely fall out so make sure you take it apart over the bench).
  10. Remove the two o-rings in the pump cavity and the shaft seal.
Inspection
Clean all of the parts and either air dry or wipe them dry with a lint free cloth. Lightly coat any machined surfaces with power steering fluid to prevent flash rust.
Check to make sure the flow control valve moves freely in its bore. If it doesn't check for burrs. These can be corrected with emery cloth.
Make sure the screw in the pressure relief valve is tight. If it isn't, tighten it. Make sure not to damage any machined surfaces.
Inspect the pressure plate, ring, and thrust plate for scoring. A polished finish is normal.
Make sure the pump shaft turns freely in the bearing in the pump. If there is any side to side looseness or the bearing is scored (or loose in the pump body), replace it with the one in the rebuild kit. I had to use a cold chisel to remove mine.
Make sure the pump vanes move freely in the rotor and check the pump shaft for any cracks.
Assembly
Note: All parts should be lightly lubricated with power steering fluid during assembly.
  1. Install the pump shaft oil seal using a 15/16 inch socket to drive it into place. Lubricate the rubber lip with power steering fluid.
  2. Lubricate the o-rings that go in the pump bore and install them.
  3. Install the dowel pins.
  4. Install the pump shaft.
  5. Install the pump ring. The arrow on the side should face the open end of the pump bore and the smaller set of holes fit over the dowel pins.
  6. Install the pump vanes making sure the rounded edges face the pump ring.
  7. Install the pressure plate making sure the spring groove is facing up.
  8. Install the pressure plate spring.
  9. Install the end plate. Force it down enough to install the retaining ring and install the retaining ring.
  10. Install the large o-ring around the pump body.
  11. Install the stud and union seals. Make sure to match the old ones up with the new ones since two different thickness’ were used.
  12. Place the reservoir in position and gently tap into place using the wood block and hammer.
  13. Install the flow control valve and spring.
  14. Install the studs and union (make sure to replace the o-ring on the union first!) and torque to 35 ft/lbs.
Installation and Break-In
  1. Reinstall the brackets and pulley and install on the car (make sure to connect the power steering hoses as well!). Fill with fresh power steering fluid, start car and let idle for at least 5 minutes.
  2. Support front end of car so wheels are not contacting the ground. Turn the wheel to the left and check for leakage.
  3. Stop car and recheck the belt for proper tension.
  4. If needed, refill the reservoir to its proper level.
  5. Turn the wheels back and forth from stop to stop until there is no evidence of foaming in the fluid. Do not hold the wheels at the stop for any length of time or you will overheat the pump. Air going through the system will make noise. This is normal.
  6. Once all of the air is removed, check the fluid level in the reservoir and recheck for leaks.
Tips to make sure your rebuilt pump lasts for a long time [top]
  • Prior to removing the old pump, flush the power steering gear box out with new fluid. The simplest way to do this is to remove the return hose from the pump and place the end of it in a milk jug. Use a rubber stopper or a cap to seal the hose fitting on the pump so it can hold fluid. Fill the reservoir and have a helper start the car. With the engine idling, add fluid to the reservoir until it comes out clear in the milk jug. Make sure the pump does not run out of fluid or damage to the pump may occur.
  • If you find metal shavings or other debris in the pump or the fluid flushed out of the steering gear box, you should rebuild or replace the gear box at the same time. A rebuilt steering gear for my American cost $149 in 1999.
  • Replace the power steering hoses. They are cheap (the pair for my American was around $30) and can be a source of leaks and debris in the future.
  • Inspect the steering coupler (its the rubber circle between the steering gear box and steering shaft). I know this doesn't affect the pump but if it is cracked or falling apart, a new one will improve the road feel of the car and remove some of the slop from the steering.
Old 10-01-2012, 07:31 PM   #6
I got given a subscription for the mag by my son, so get it early.
I was at the supermarket this morning and saw the Decemeber copy with the Power Steering Pump article in it.
Has a burgandy 1970 Plymouth with twin hood scoops on the front cover.. and a hot girl with a stars and stripes top on...
Note I mentioned the car first... I want one of those!
Old 10-02-2012, 07:27 AM   #7
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Keyair, is the Saginaw pump a hydroboost unit?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 10-06-2012, 12:16 PM   #8
I believe so.
All of the info I have read about doing a conversion from booster to hydraboost, the only mention of the pump is in how to change the plumbing from it supplying just the power steering to the HB as well.
I believe the saginaw style pump is the normal pump... I have only ever seen those style pumps on Chevy powered trucks.
Feel free to update this if I have it wrong!
Old 10-06-2012, 12:25 PM   #9
I'm wondering if I should buy a rebuilt pump or attempt to rebuild mine?
Old 10-06-2012, 12:37 PM   #10
Dean, whenever I ask that question of myself I base the decision on whether I have the time to do the rebuild. If I don't then I buy a replacement, if I have time then I'll tinker with until I break it and then I buy a replacement
Old 10-06-2012, 01:09 PM   #11
Very good logic Brad!!!
I guess if it is leaking and you have time, I would buy 2 rebuild kits and do the rebuild, keeping the other $8 investment for emergencies or if you nick a seal when doing the job.
If the pump is noisy or suspect, I would get s new one.
Keep in mind, most of the rebuilt units, they clean the core, and just put the seal kit in, and shoot a coat of paint on it!
Old 10-06-2012, 09:31 PM   #12
Well if I don't break it, I'm guessing I have a 50/50 percent chance of having to pull either one back out!
Old 10-07-2012, 05:14 AM   #13
Other quite good rebuild pages here...
Power Steering Pump Rebuild (Saginaw) (301 pump)
Saginaw Power Steering Pump Rebuild
Old 10-07-2012, 06:27 AM   #14
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
I remember replacing the power steering pump on my 79 to be a real pain due to accessibility, replacing the alternator was a walk in the park comparably.
Shoot for 100/0
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
